nycarrival
- Joined
- Jan 9, 2021
- Messages
- 50
- Likes
- 1
Can someone help me choosing between HD600 and HD6XX? The 6XX from drop appears to be cheaper however a few extra bucks should not spol the party. Thanks for your help!
If you have my ears/brain, neither. The 650 sounded too good - a decade of use led to Tinnitus! If you do go ahead, use at lowest volumes, and take lots of breaks. Personally, I wish I'd just ignored headphones, stuck with speakers, and had more silent hobbies. So my recommendation would be buy a kindle and read more...
There are better options than HD58x for the price, EQ has less chance of success if the pinna rise and adjacent ranges aren't decently defined IME.I think I might roll with the 58X, a bit cheaper than the 6XX and they will be EQd anyway
What Mal said above, watch those EARS,
Over a decade of working around Jet engines, with ear protection, blowing gas lines (as loud as a jet engine), hard on the ears,
Just Saying
I'm assuming you like the DTs? I've heard a lot of neg things about BeyersThere are better options than HD58x for the price, EQ has less chance of success if the pinna and adjacent ranges aren't decently defined IME.
I like their DT880 and DT250-250, not DT250-80 or DT990. For other brands I like AKG K612, but not K702. I like AKG K371 and Shure SRH440 to mention a few closed backs from other brands. Hope this gives you an idea.I'm assuming you like the DTs? I've heard a lot of neg things about Beyers
Thanks, I did want to mention also, these will be run thru a Btr-7I like their DT880 and DT250-250, not DT250-80 or DT990. For other brands I like AKG K612, but not K702. I like AKG K371 and Shure SRH440 to mention a few closed backs from other brands. Hope this gives you an idea.
With my ears, EQ is a must for meI have both the hd6xx and hd600. I don't do EQ and I prefer hd600 but again that's just me.
32 Ohm version would be the best to get, it's also lower distorsion.Thanks, I did want to mention also, these will be run thru a Btr-7
Yep, Thanks32 Ohm version would be the best to get, it's also lower distorsion.
Which 3rd party pads do you have on the HD6XX? You can't tell the difference even with those pads on?I can't tell them apart.
