Choosing an Amp for Warm Speakers – Need Advice
I think your ambition has moved beyond what the speakers can deliver. Your equipment is good (Topping and Yamaha). The obvious weak link is the speakers in my opinion. Don't buy more amps or DACs - get a new nice pair of speakers and demote the old ones to surrounds.
Thanks for the response, I called a few hifi companies and they mostly told me the same, I need better speakers.
Thinking of going to Canton or Heco, maybe Focal at 1k price point, new or used that are up a tier.
A DBR62 is already up a tier and those cost as little as 250 per pair depending on location.
With 1k, you can buy a lot better than Canton/Heco/Focal IMO.
For example: https://testedaudio.com/products/speaker
I have an older generation of the Diamomd series the 220’s and they have a great mid and high frequency response. It’s difficult to say without any measurements on your model but the diamond series is generally well regarded. I think the boomy bass could very well be due to a room mode. If you were able to tame the boomy frequency with EQ it would clean up the sound and benefit the entire frequency response.
Also, have you got the speakers wired up correctly? Getting the terminals mixed up is easily done and could have that effect on the sound.
By the way, a Hifi dealer is only going to be interested in you spending your money on something they sell. You will get the best advice on this forum and you can’t go far wrong with equipment that has been measured and verified.
Those are some very linear measurements honestly.
I asked about the Elac DBR and he told me those have a spike in the highs and are not that pleasing to listen as "warm" speakers go.
Searching for speakers with a particular sound profile is what caused your problem with your existing speakers. Linear is what you want. If you want a "warmer" sound then you use EQ to give boost to the low frequencies, probably a 2-3dB shelf below 200Hz or so.
The OP fled ASR months ago.
@Good Vibes the Diamon 220 have a different sound from I researched, the problem with mine is the boomy bass, I need to crank the bass down and the treble up, there are no details and sound stage in the voices, the DAC introduces some details with the instruments like the guitars and sharp, fast sound, but again it seems in lack some details in the mids or 12-20k range from what a friend said to me. I need to invest in a mic or something to be sure.
Maybe the speakers are just at their limit and can't produce more.
@staticV3 I've seen some Canton Reference 9.2dc for the same amount as Elac DBR62 in the 500 Euro range, the Wharfedale Evo 5.2 around 600 Euro new, but I am not sure I want to go to the same speaker brand.
Those Ascilab are nice, but pricey...are they placement dependent as other speaker or are Elac also?
If you can start with measuring, a good mic and getting an impression should be your first thing. It will help you again and again.
The Canton Reference are very nice speakers. I think they will beat the Elacs easily. But honestly, better get the Ascilabs. Just my opinion (owning quite some Cantons and a pair of Ascilab C6B).
I think there is something wrong with your set up. I searched for measurements of the 11.1 and found this: https://www.hifinews.com/content/wharfedale-diamond-111-loudspeaker-lab-report
The results in that test show that they have a rise in treble, indicating to me that the issue you are encountering is regarding set up. Double check you have the cables correctly connected to the amp and the speakers. The sound you are getting could very well be a case of misplaced wires. If they are wired correctly, the boomy bass is going to be distorting the sound and making the mids/treble sound muddy. It will be most likely an issue with your room and the speakers placement. Moving them even an inch can Change the bass response significantly. Also, do you have the speakers on stands or a cabinet? That could also be the root of the problem.
Buying speakers is part of the thrill of the hobby so if that’s what you want to do then go for it but it’s in your interest to check the issue isn’t with your set up first.
By the way, you will struggle to find a better speaker than the Elac for €500. They have been measured and they are superb!
Adding to the the good recommendations by fellow members: There is no such thing as a "warm" amplifier. Outside of having the appropriate level of power and being able to drive the impedance of the speaker, the often propagated speaker-amp "matching" is not a real thing. Modern amps (apart from the cheapest class D without PFFB) have a flat frequency response and don't alter the sound characteristic of a speaker.
This was different in the time of tube amps: Due to their high output impedance, they often influenced the frequency response of the speaker. That's not the case anymore and hasn't been for decades, but this audiophile "wisdom" has lived on and refuses to die.
Look for features, power, price and build quality, not "sound".
Hey Random just wanted to complement you on this post. Well said and concise. I actually saved it !
The cables, Supra cables are fine, they are placed on PAL furniture 1.5 meter of so from the side wall each and 50cm or more from the back walls, mine are Diamond 11.2's.
Will a a pick with their placement later.
Ahh ok, luckily the 11.2’s have been measured on Stereophile.
