This is for a home studio
I wish to upgrade from some old audio interfaces by EMU and Echo Audio, which are no longer supported with current low latency drivers (WASAPI or ASIO), for Windows 10 and 11. The EMU drivers typically need workarounds @ installation and are broken by each major Windows update, which overwrites the drivers, and I am not sure how long the obsolete Echo Audio drivers will work well on each new Windows update.
The traditional route would be to purchase a typical similarly functioning audio interface from the likes of Audient, Focusrite, M-Audio, Native Instruments, etc, etc. The challenge with these is that the gear is built to a budget. Nowadays what you get is much better from a specs point of view. Decent specs but I no longer wish to buy, as much as I can help it, an integrated device. These audio interfaces, and that also applies to my EMU's and Echo Audio units, are a combination of :
Headphone amp, ADC, DAC, physical knobs, some digital inputs, and maybe some digital outputs, some analog line inputs, some analog line outputs, optionally MIDI, and microphone preamps. The inexpensive gear has usually a few compromises - no line ins that bypass the preamps completely ( I have two stand alone preamps so do not need a preamp - one has digital coaxial and optical outputs also), Their headphone amps are sometimes unsuitable for low impedance headphones, cos they are geared towards the traditional large over the ear dynamic studio headphones - e.g Senny HD 600 or HD 650. The Audient audio interfaces for example have an output impedance of 22 Ohms - too high., for my 17 ohms IEMs., and cos they are built to a budget, their headphone amps are not assured to support a variety of headphones.
The other thing with these all in one audio interfaces, is when you replace them, you have to take out of service, the entire audio interface, which has perfectly usable bits, but that's it gone, kind of like an integrated amp in hifi, or a combined CD player, Preamp, Amplifier - you lose the entire thing.
So my current strategy is separates. I have a Sabaj headphone amp on the way - so I just need a good ADC/DAC device, which connects to USB so I can have audio in and out of Windows, on low latency WASAPI and ASIO, to feed this headphone, and active speakers, and I can feed the analog line ins, from either of my microphone preamps line outs, or feed digital ins from the digital outs of one of my microphone preamps.
Rather than assume I have to go the traditional route, I'm just checking, are there any other options out there. I could go and just buy some RME high end audio device, which would last me a very long time, but these things are expensive - over $1,000 and their headphone amps would be a bit of a duplication, since I already have a headphone amp that I should be perfectly satisfied with, and preamps that are adequate, so I do not need their preamps.
In the good old days, audio interfaces and preamps were separate devices, before the invention of these ALL in ONE's.
I've been highly impressed by the excellently performing Chi-Fi segment, if measurements mean anything. Do they have anything with similarly measuring specs to an RME audio interface (or ideally better than), which cuts out this huge expense of buying an RME. I do not need the fantastic routing capability of an RME, cos I have other virtual I/O drivers to achieve this, using my DAW Reaper, so all my routing of audio on the computer is done within Reaper, just as good as I could have done on an RME device, and probably better, cos the RME is limited to EQ and compression and reverb, while with the power of a full DAW, using all the power of the CPU's, I have an unlimited choice of how to process and route audio - within the computer.
The only advantage of an RME device would be driver support, but for a huge chunk in savings, I'm happy to live with that risk.
I may still end up with a traditional audio interface - low cost budget one, or a high end one, but 1st I'd like to double check, have the Chinese manufacturers or Americans like MODI, got anything - value for money with impressive specs, which I could use? SINAD as close to -120 dB as possible or better, on analog ins and outs, proper management of jitter from and to digital sources - via good quality reclocking/PLL whatever, low latency drivers, and if its possible to route analog ins straight out to analog outs for true zero latency monitoring - that would be a bonus(not compulsory - only nice to have - I think with good low round trip latency on a powerful computer, this requirement is not vital) - The power of the headphone amp, if it comes with one is not important, it will only serve as a backup/duplicate, since I already have a good headphone amp.
Any suggestions please.
