Afternoon all.
I've been tinkering with one of these cheap Chinese JL Hood Class A amps and I wanted to remove the volume pot to run it as a pure power amp.
I was looking at the signal wires trying to work out how to remove the pot and directly connect the inputs to the amplifier boards when I noticed that both the left channel and the right channel signal wires connect to both amplifier boards and then join together in to a single signal path.
The pot is an ALPS 100kA x2, so there are 3 wires at each stage, left / right / ground from input to the pot and then the same left / right / ground to each amplifier board, at which point the left & right signal appear to combine in to a single trace.
I'm struggling to understand why this is the way it is, is it some kind of feedback or some method of increasing the signal voltage by combining left & right signal?
