sigmatechnica
- Joined
- Jan 19, 2020
- Messages
- 8
- Likes
- 2
Im looking for a good ADC to make measurements on my other diy audio gear. I'm planning to add some attenuators and buffers to the frontend and make it into a 'proper' measurement instrument Some requirements:
* USB (i suppose spdif could be made to work, i'd have to worry about getting it into the pc though, usb seems easier)
* I don't need load of channels, 2 would be fine. 1 would be fine but they don't tend to come in 1's!
* If it comes with an ok dac in it, great. if not i can use some other signal source for testing. Good dacs seem easier to find and better documented than good ADCs
* linux drivers available. Various ancient m-audio fireware and usb interfaces i have had previously have been problematic in this respect.
I was considering one of the pro audio interfaces from Focusrite, Behringer etc, not sure if they are the best though, after much research on the UMC202HD i discovered the adc in it is not that good. most of the measurements people have done tend to focus on the dac side.
Does anyone have any suggestions of something that might be suitable here?
Thanks!
Thanks!
