Hi everyone,
I just replaced my old Nad C320 which died. I acquired two Fosi Audio ZA3 (was a bargain, not particularly thinking of using them in mono, most likely I will offer 1 to a relative/a friend).
I had a few cheap speakers in my life, but my preferred ones are the KEF Coda III (both dead now) and my current KEF C42, that are very inequal.
I listened to ATC SCM40 once and I was amazed; and I saw a pattern: sealed speakers. I love their bass response. And placement will be much easier in my small flat (currently 30cm from a wall, not in the corners). Even if I don't have a lot of low-range on my KEF C42, I would like to find a good replacement to them, that is also sealed, with this dynamic/clean low-range response. I am listening to minimal house/techno, mostly.
Thanks in advance!
Pierre
- What do you think would make sense on the second-hand market in France? (below 300€/pair) In particular, considering membrane/capacitor checks on old second-hand models.
- And also, I was considering building some 2 or 2.5-way passive filter sealed DIY speakers during the winter, is it worth the hassle? (I have a good supplier of laser-cut Norwegian birch plywood, for what it's worth)
Thanks in advance!
Pierre
