Chase Technologies RLC-1 Remote Line Controller
john61ct
This legacy rackmount "control pre-amp" features volume control tied to an automatically variable Loudness Contour circuit. Cutting the power resets to a standard default calibration of the "stop contouring" reference volume.
Opening the case and modding the innards is required to disable the loudness compensation. Some do this to enable its use as a dedicated "bass boost" instead, controlling overall volume elsewhere.
Also controls for balance, bass, and treble and source switches 4x inputs.
Single-ended RCA analog line-level I/O only, pure passive.
A separate fixed tape / line-out pass-through pair bypasses the internal volume, balance, and tone control processing.
Comes with a remote, and is in fact useless without it. Thus, units on eBay missing the remote are very cheap, just won an offer for under $25 delivered, and a replacement remote for $35.
I plan to try to find a programmable "IR Blaster" and "teach it" to work with the RLC.
Apparently uses standard 38kHz infrared pulse IR audio commands. Protocol: NEC1
Device Parameters (Device / Sub-device): 128, 109 (often listed as 128.109)
All suggestions and feedback welcome.
Related thread:
