- Thread Starter
- #41
That is a beautiful poetic question! But to look at it from another angle: a diamond doesn't change its structural properties or its value just because it's in the dark with no light source to observe it.This doesn’t follow at all. Any proper amp design would filter out any frequencies it should not amplify. They are specifically designed to block and RFI at these frequencies.
It is similar with an analog architecture. The native speed, stability, and phase linearity are internal properties of the circuit itself. Testing it at 1 MHz without filters is not about trying to "hear" the ultrasound.
The real question is: if a topology possesses the native capability to handle this high-frequency energy directly without falling apart, won't those exact same internal properties remain active when it operates back down within the standard 20 Hz - 20 kHz band? Can those hidden capabilities be the reason behind a deeper, blacker background and better spatial delivery in the audio range?
Thank you for bringing this fascinating perspective into the discussion!
Best regards,
