Hi all,
Inorder to get better (potential) SPL handling and seamless sound, I was thinking of using 3 centres for LCR
The speakers in consideration are KEF Q650C and ELAC C6.2
I plan to keep L & R vertical (though for KEF I can keep all 3 horizontal) as MTM design
I want to avoid floorstanders, to keep all speakers (except subs) off the floor in the living room.
I just wanted to confirm if this approach is better than using corresponding bookshelfs for L & R (Q350 and ELAC B6.2 which would be my sides and surrounds anyways)
Or there won't be much benefit (maybe something to do with the drivers used in centres)
My room is 22 ft W x 14 ft L x 9.5 ft H, and non AT screen (and hence centre would have to be at the top or bottom of the screen) being on the longer wall
Thanks!
Thanks!
