This is a review and measurements of the Centrance DACport Pro portable balanced DAC, monitor controller, and headphone amplifier. It is on kind loan from a member and costs US $350 (discontinued?).
The recessed dip switches require a tool to adjust so if that is something you are going to want to change a lot, will be a pain. The volume on top is very nice as are the super bright LED bar graphs and clipping indicator. Rear side sports dual full sized XLR connectors which is a nice benefit over just about any consumer portable DAC & HP Amp. Build quality is very nice and there is little to complain about.
I have abbreviated the tests in the interest of time.
Centrance DACport Pro Measurements
Max output from the XLR connectors is 5.6 volts. I adjusted that down to 4 volts and got respectable results:
EDIT: the FFT is much cleaner. I must have taken a snapshot in between captures.
Same with dynamic range:
Noise floor is a bit high and a couple of jitter components are visible:
But this is fine in this class of product. Same story with wideband noise+distortion vs frequency:
I think the unit broke all records in how *little* power it produces in low gain!
High gain does much better but has that strange constant distortion past 2 millivolts into 32 ohm. Noise floor is extremely low gain so very suitable for IEMs. Headphone better be very sensitive or they won't get loud enough.
The DACport Pro targets professional IEM/headphone monitoring and for that task, it seems to perform rather fine. Its DAC is with XLR output is certainly good enough. Wish there was more power from headphone output though. There is more power from a candle light than this thing in low gain mode!
I am going to recommend the Centrance DACPort Pro for its intended market.
