MattHooper
- Joined
- Jan 27, 2019
- Messages
- 10,914
- Likes
- 19,373
Is that….a bed?
Perhaps our systems are just not resolving enough.No offense but it is obvious that many of the commenters in this thread stating that "timbre-matching" doesn't matter don't care much about home theater and/or have severely compromised systems.
Nah, it's those hunks of lead on your head you call "ears" that are the problem.Perhaps our systems are just not resolving enough.
Is that some lame attempt at an audiophile joke? I'm not in that camp at all, but I don't think comments about timbre matching center channels from someone who has their center located behind their TV and aiming upwards add any value to the conversation.Perhaps our systems are just not resolving enough.
I dunno - it looked to me like you just came out with that exact audiophile cliche - just reworded.Is that some lame attempt at an audiophile joke? I'm not in that camp at all, but I don't think comments about timbre matching center channels from someone who has their center located behind their TV and aiming upwards add any value to the conversation.
I have plenty of compromises in my setup too, but have a lot of similarities with the OP.
Perhaps you should slow your roll, I implied nothing of the sort and am the exact opposite of the audiophile cliche.I dunno - it looked to me like you just came out with that exact audiophile cliche - just reworded.
Neutral speakers do not sound the same...a KEF R3 does not sound at all like a Revel Performa3, even though both are neutral -- the soundstage width is dramatically different for one thing and you can't EQ that. I agree that the majority of us have to have several compromises, but it's not that difficult for OP to have a "matching" center (the much cheaper C208, which I recommended above).If you choose only to use neutral loudspeakers, then by definition they are timbre matched. If not, then timbre mismatch will just be an additional compromise.
(my bold)No offense but it is obvious that many of the commenters in this thread stating that "timbre-matching" doesn't matter don't care much about home theater and/or have severely compromised systems.
EDIT: It's quite safe to say that home theater is an afterthought for most of the members here -- there's nothing at all wrong with such people, but they aren't exactly the most qualified to comment on this particular topic, is that fair to say?
When you have a multi-channel system, the directivities of the different loudspeakers become a lot less important. The "soundstage" will now, if you have your system setup properly, overwhelmingly come from the spatial cues in the multichannel recording. The reflected sounds will be overpowered by the sounds from the multiple channels of loudspeakers surrounding you. That's why it is most revealing testing loudspeakers in mono.Neutral speakers do not sound the same...a KEF R3 does not sound at all like a Revel Performa3, even though both are neutral -- the soundstage width is dramatically different for one thing and you can't EQ that. I agree that the majority of us have to have several compromises, but it's not that difficult for OP to have a "matching" center (the much cheaper C208, which I recommended above).
Yes, they seem to blend just fine in my setup, and I'm sure Dirac correction helps keep the frequency response matched relatively closely. I only use surround channels for home theater, and I haven't had any noticeable issues with surround effects. The Q4 also has enough bass extension to provide some limited support in Dirac ART as well. I'm sure M126Be or bigger speakers would be better, but for me, I don't think I'd notice significant differences in fidelity like with the LCR channels.Great to know! Have you found the KEFs and Revels blend well enough for surround/height channels for your use case?
Yep, that would be one of those. My personal preference to sofa and shared with my two girls. No wonder I am an OddballIs that….a bed?
When I had mine and measured them it looked like the +/- 3db point was around 20 degrees either way, wish I could have found a way to make them work ceiling mounted, interested to see what you are able to do with them.Yeah, I'm planning on basically just firing straight down from the ceiling. I'll probably angle them a little so MLP is only around 15° off-axis, but they're still nice and wide.
You should be able to get a great deal on C426. I got mine for EUR 2.8K which was 50% off the listed price with some extra shipping on the top. Black new unit came in pristine condition from Germany.It seems like there are two schools of thought:
I'm now really tempted to get the C426Be and try blind AB testing with another neutral speaker to see if I can tell them apart while panning.
- Neutral, well dispersed speakers are already timbre matched enough
- Exact timbre matching (within line or exact model) is distinctly audible (possibly due to dispersion, phase or some other characteristics)
If I can't find a good deal soon, I'll get the Genelec and wait for a used one to show up. I'd probably need to run dirac for them both on a miniDSP to have calibration profiles for each channel, and set up some kind of macro to toggle channels with a (blinded) single button press in the MiniDSP interface...
