- Thread Starter
- #21
how far away do you sit from the front stage and how far apart are the L/R?
About 3m (so slightly towards the back of the room).
I can see how that makes sense if it's in the low frequency range where the sound output is ~omnidirectional, but if the speaker is close enough for the SBIR range to be highly directional (say >500Hz), then surely the rear output from a sealed unit is minimal, so there's way less interaction than there would be in a ported design?The only way to avoid it (for the wall that would be directly behind the speaker, which is the most significant source of SBIR) is to put the speaker in the wall so the baffle is flush with the wall (i.e. infinite baffle).
tl;drEdit: corrected spelling of 'timbre'
Asked AI, which decidedly confirmed, that center is integrated in signal panning. That would as much decidedly ask for a) consistent amplitude and b) same phase response over all three front channels.tl;dr
All your choices would be way beyond my budget. Still the question in general is very interesting. I would start w/ a basic one.
Is the content of the center independent of any other content in the speaker array? Or, alternatively, does the center share any content w/ the other speakers?
What do you think, consequences?
Maybe I'm misunderstanding though.
In any decent design there's no meaningful output from the port once you're well away from the port's tuning frequency.I can see how that makes sense if it's in the low frequency range where the sound output is ~omnidirectional, but if the speaker is close enough for the SBIR range to be highly directional (say >500Hz), then surely the rear output from a sealed unit is minimal, so there's way less interaction than there would be in a ported design?
Speaking from the cheap seats here—I had a 5.1 system collected from bits and pieces from a thrift store in Fresno California. I suspect a lot of local professors at the J.C. were either moving out or replacing 5.1 systems with soundbars. There were AVRs, Blu-Ray players and speakers going out the door for silly money. My first 5.1 systems had different speakers in the back from those in the front, different center speakers as well. Then, one fine day, a dedicated set of surround speakers showed up, Infinity Primus 360s, 250s and C-12s, all for the low, low price of $79. Having 5 speakers of roughly the same timbral qualities made a huge difference. I wasn't using the system for videos; it was for 5.1 SACDs and DVD-A recordings. The image in front was much more continuous, the sound in the back as well. I'm not sure what you should do with such pricey speakers as yours but getting close to the same timbre surely would help.“All loudspeakers in a surround system need to be comparably good from a timbral perspective, and, if it is affordable, all the same.” - Floyd Toole
I always thought this would be a thing and I get how it probably is. With my centre speaker which has the same drivers as LR but has a much narrower dispersion pattern due to a waveguide and crossover I definitely can hear a difference between the speakers however at least with what I am watching just television dramas streaming from the TV internet website it seems to have much more basic surround recordings I think. It doesn't seem to play in the way I thought it would. Point is I suppose it depends on what your watching and if your listening to music upmixed.It’s definitely a thing!
Loudspeakers can vary so much in terms of colorations, resonances, dispersion patterns, etc. If you have timbral mismatches between speakers, especially LCR, you can hear the timber of sounds and voices change as they pan across the different speakers. I find it very offputting. And I’ve heard home theatre systems where the person really cared a lot about getting good quality LCR speakers but figured “ anything will do for the surrounds” and I could totally hear the mismatch and quality when the sound went to the surrounds. The people in question didn’t care about it, but I certainly noticed and I care about such things.
Of course, if you buy good neutral speakers with the relevant dispersion pattern… well that is timber matching and it will sound better and of course that’s part of the point.
