CEC BD1000: Increasing the current 32.5 rpm
AJM1981
iu
Today I measured my classic belt driven CEC BD-1000 (50hz) rotation speed and it unfortunately spins at 32.52rpm (min/max32.46 to 32.59). I noticed it earlier on after a new record bought for our daughter sounded slightly more mellow compared to what she usely played on spotify. It is by far not in the disturbing zone, but maybe an attempt to adjust it to 33,33 is worth it.
A new belt was already on the list, also I will apply some oil soon (read that sewing machine oil is ok). But those things are probably not fixing the issue.
I read that checking the pulley for the correct diameter might be one to try or adjusting the potentiometer when possible. I know I am not a mechanic by far, but when it is not at microlevel and with a good reference I might try some things out.
Any recommendations?
Well, belt thickness does play a role in terms of transmission ratio. Thicker belt -> higher speed.
Greetings from Munich!
Manfred / lini
Manfred / lini
Might try it as a first step, if that ups it to at least a bit of a closer to 33 rpm rotation speed.
Search for ProJect speed box first version with 240 Volt output. Only used available i think.
Or search for frequency regulated power supplies.
new belt is always a good idea!
Thanks for the tips. I will see. I do not get the idea the old one is anywhere near a bad state. Maybe it wasn't that old either. But will compare it to a new one I ordered for a bit. Maybe there is a slight to noticable elasticity difference. Wonder even if two belts can be combined if they are about the same in state and diameter.
For what it's worth, when I went to purchase a bottle of oil for my mom's Singer sewing machine a few years ago, I visited a shop specializing in the things, and was told that any vintage green-and-white cans of Singer-brand oil should be discarded. I didn't ask why. The recommended replacement was water-clear, while the old stuff was honey colored. Such oil might be okay for a turntable motor, but it's probably too thin for the bearing.
What speed did it play at before when things were new? One reason I went with direct drive a long time ago.
How was the speed verified? Was it checked using multiple approaches? (For instance, methods using smartphone apps can be inaccurate.)
I got it second hand last year or the start of this one. It is a model from the 70s. Given the hz rate, I assume it should have been around 33⅓.when it left the factory.
Fun thing is that I only noted this with a second pop album which was not mine. It was not that it sounded off. I liked another pop track of an earlier bought compilation actually better than the original as one song sounded like slightly laid-back cruising version. Since that one was labeled as a different version, I assumed it was simply the version itself. I gambled at a .x amount slower before measuring, because I sometimes used to tweak the frequency rate in these small values when producing.
The speed of my turntable matches A429hz. When speed is marginally constant the difference between the standarized A440hz or some fan favorite A435hz or perhaps even some baroque tunings of A415hz are barely noticable to many without reference. I would even suggest that the mains of users that have used vinyl might have had a slightly slower spin rate by time, perceiving vinyl as more relaxed and warm without being able to pin it down (besides mastering differences). Not talking about the absolute audio purists here who always measure, and I don't count myself in because I only measured recently, not from day one.:)
CEC made 10,000s of those things, many of them rebadged by Sanyo, Radio Shack, Marantz, etc. Not sure how handy you are but this is really good youtube video of a complete teardown and service of rebadged CEC. He does it in about 1 hour, so a weekend afternoon project. A proper motor teardown to remove all the hardened lubricant might make the difference (+ a new belt).
Also, that belt size is a bit odd, if you're in the US and you haven't ordered a belt yet, get one from https://www.turntableneedles.com/ They have a pile of belts and are knowledgable, so just ask them to fit you with the correct size. I think it's 25.5 or something and quite wide, better to just ask.
One hour for a specialist indeed makes a weekend project here. That's one worthy to watch and use as a guide, thanks! I already ordered a belt in the previous days that should be the one for this model, will see what it brings. Also the damping material inside the casing might need some verification
Last but not least I would like to see if I can tackle, to what seems, a mild inner groove distortion issue. All should be doable at some point as these were perhaps a thirteen in a dozen, but still quite proper turntables for their time.:)
This is caused by misalignment of the stylus. With proper means (I use the Schön Schablone) you can fix this easily, just take your time and don't use too much force on the pickup screws.
And give us a speed update in a few months...
Or not.
If you haven't sorted the tracking error problem, you can check the cartridge overhang using the mat. With the arm centered over the spindle and the cartridge centered in the headshell the stylus should line up with the inner ring of the platter mat. Overhang for the CEC arm is 50cm, so you could also use a ruler parallel with the top of the headshell measuring from the back of the rubber washer on the headshell to stylus tip. If you adjust the cartridge, recheck the the tracking force by zeroing the arm, resetting the counterweight gauge and adjusting accordingly. The gauge, at least on my arm, is reasonably accurate. Ideally, anti-skate should be disabled when setting tracking force.
