CD52mk2 Special Edition measurements
horias2000
Cluj-Napoca, Romania
This is an update of the initial measurements I did here: https://www.audiosciencereview.com/...special-edition-cd-player.57160/#post-2089935
I wanted to make a new post instead of continuing the one from the link as it will help to see the actual performance as the initial measurements were flawed. So if you want to see how the device looks on the outside and inside, visit the thread from the link above.
My measurement setup is made out of an E1DA Cosmos ADC (grade A) and a Cosmos Scaler. Both devices are powered from battery packs (each device has its own pack). The CD player is connected to the Scaler via a single ended cable. For test signals, I used @NTTY 's test CD.
Let's start with the 1kHz test tone:
This looks really good for such an old device. Having a SINAD of 91.4 dB is great considering the results @NTTY got on his CD players.
Next is the 1kHz test tone with extended frequency, up to 48kHz
Now 1 kHz test tone but at -3dB FS
We naturally see a decrease in SINAD but it's still pretty good.
Multi tone:
This looks very clean!
Next we'll have a look at the frequency response:
Nice and flat in the audio band
Net we'll have a look at the filtering performed by the device (this is a test that @NTTY does and I thought it's nice to include it as well):
Jitter:
This doesn't look too clean but comparing to what @NTTY is getting on his players, I think this is good as this is the limitation of the test CD.
Next I looked at two-tones signals to see IMD:
Again, very good results.
Now a look at inter-samples as per @NTTY did (unfortunately I forgot to increase the sampling frequency to 192kHz so it only goes up to 48 kHz):
we have -34dB at 5512Hz, -27.6dB at 7350Hz and -16.2dB at 11025Hz
And lastly, the THD vs frequency plot:
Conclusion:
I'm happy to say that the CD52mk2 Special Edition is a good device. I enjoyed listening to it for some years now and I was hoping it will not disappoint on measurements. It didn't. Most of the time I listen to it through my SU-9n DAC but from time to time, I switch to its analog output, just to listen to the 1bit DAC that's inside.
THD is at -97dB so it's clear that the DAC and the analog circuitry works really well. Noise isn't bad at all for a consumer device.
Multi tone:
Jitter:
Conclusion:
Nice review, thanks!
Did you check for intersample overs?
Very nice and thank you for the update!
These are good performances indeed. Note that the ENOB is incorrectly calculated because of the -7dBFS attenuation that the ASIO driver sees at the input of the ADC. So it's roughly 1bit lower than what is showed (ie. 15.7bits, which is very good).
This is very close to the Teac VRDS-20 which was using the TDA1547 as a higher end DAC to complement the SAA7350. So now we know that a a standalone DAC, the SAA7350 was already very good.
May I recommend you use smaller print-screens because it's difficult to read when on a mobile phone?
Can you add the THD vs Frequency @-12dBFS too?
Cheers
Cheers
Done! I add it at the end. I will try and use lower resolution images for the next one. What resolution works well for mobile?
The size below is ok (example from a low value Pioneer PD-30 which I will review soon):
As you can see, I first copy-screen an overlay of L+R channels, and then I insert the dashboard of one of the two channels.
About the THD vs Frequency, in the overlay window, set it this way:
So it will show distortion in dBr on the left and % on the right (and I set -40dBr as top graph axis limit, that's 1% distortion).
Cheers
Cheers
Done! I updated the THD vs frequency plot. Thanks for the input.
The [picture] size below is ok [for mobile] (example from a low value Pioneer PD-30 which I will review soon):
By the way, it is OK for a desktop computer screen also.
