I apologize in advance if this is the wrong forum.
I currently have a modest system in a small room and am using a Sony DVP-S9000ES player.
The Sony unit is beginning to fail; it is struggling to read discs and the eject button is broken. Given the age and condition of this player, I am wondering if it is worth having it repaired, or if I should invest that money into a new player such as a Denon DCD-900NE, Rotel CD11, or Onkyo C-30? I understand these models aren't SACD.
I am biased and believe that replacing a Sony ES player is difficult at best, regardless of costs, or what you're willing to pay to play your glorious CDs. I you have access to a shop that could and would repair yours I'd try it, but be sure of it, and I'd expect them to restore it to what they and you consider like new, including repairing or replacing that "eject button" and its operation.
Otherwise, if you're in the US, I would shop very patiently here:
https://www.ebay.com/sch/i.html?_fr...player&_sacat=0&_odkw=yamaha+r-s602&_osacat=0
I am partial to changers, so a Sony CDP-CA8ES was my second CD player (after another Sony unit) -which I purchased around 1990, and which served me joyfully for about 20 years. When the display started to go on that, I started to use the link I share now to identify a backup player for the time the day came. Sure enough, the CA8ES started to go quickly after the first issue surfaced. Fortunately, I had been lucky to find a CDP-CA9ES in like-new condition. The unit came with an original manual but not its remote, though that still worked for me because fortunately it uses the same remote as the CDP-CA8ES, and that and the player have continued to work fine for me.
That is what I would do again and recommend to you as well, and you can try to get whatever ES unit appeals to you. I was patient and lucky and wish you good luck as well.
Otherwise, Rotel and Onkyo would be the other brands I'd trust -I own and enjoy one nice unit of each. For SACD specifically, I have a Yamaha DV-S1800 which plays DVD-A discs as well. I also bought this used, though from a distributor and it came with everything besides being in like new condition.
Enjoy your patient shopping and good luck with your eventual selection!
