the desired room properties of a 2100 hundred-person vinyard shaped concert hall for original music production on the one hand, and a large-ish home listening room with a disproportionally large near field for recording-repro on the other hand, are diametrically opposed.
Absolutely true, reverberation time and initial delay time are necessarily completely different, and so is real source localization vs. phantom localization.
Nevertheless my personal take on the matter is we can learn something from concert hall and studio acousticians.
early reflections are detrimental, because they blur the image. We can't separate them from the direct sound when under 6-10 milliseconds, resulting in them being perceived as part of the direct sound, aka time smearing.
I am not so sure about time smearing for such early reflection. They do affect localization, but only if being discrete enough and localizable at the same time. If reflections in this early window (sometimes referred to as the ´Haas effect´) are sufficiently diffused in time and angle, the are more helping perceived dynamics and loudness and not so much deteriorating localization.
Late reflections less so, because we can separate them, recognizing them as a separate event (echo), which adds space. Not always good, but better than smearing.
It very much depends on the time, direction and pattern of the reflectogram. If it is a meaningful reverb pattern, as our ears would expect it from a cathedral or reverberant concert hall, it is actually not as much ´smearing´, if only the direct sound and very early reflections are consistent and dominant. The word ´echo´ implies a discrete, delayed sound event which our brain can perceive as kind of a second wave of direct sound, and it is very bad for any occasion (read about the Munich Gasteig Philharmonie disaster if interested).
Dipoles and Line Arrays (and various other speaker concepts) address both. Less total room reflections on account of their radiaton patterns, but much less early reflections and only somewhat less late.
As mentioned, my experience with dipoles is mixed. They might be a solution to keep the directivity constant and the indirect soundfield tonally balanced (as the late S. Linkwitz pointed out), but particularly at higher frequencies, they tend to add a pretty discrete, pretty early second wavefront, which is reducing the critical listening distance from a practical perspective significantly.
The openings are to the sides, so a dipole null will be present there?
Null is in the direction of both openings having the same distance from the listening/measureming perspective. To the left and right on the sketch.
But they sure work well as tweeters crossed at 700Hz up to some 18kHz without issue. Some of the best tweeters he ever tested, said Chua (ampslab-spk.com). Few artefacts, great HD, he only did not publish of axis SPL, so i will mail him if he has any data on that.
I don't doubt this, such planar tweeters can withstand a lot of power, too. I just see the difficulties when it comes to bringing such to constant directivity. The active wavefront area is just very huge, and applying waveguide or anything is rather complicated. Maybe I have not seen the right solution to date.
