Compact folded-baffle dipol subwoofer, looking like this:
For two-channel stereo, a compromise is mandatory. While under anechoic conditions, a surprisingly consistent imaging including limited angle of reverb and depth-of-field can be achieved with recordings containing a significant level of reverb from the concert venue, this is not the case with ´dryer´ recordings or such with mostly decorrelated reverb (like pop, rock productions), they appear with annoying proximity. The second problem is our auditory sense being used to a certain level of reverb coming in from the sides, the rear and from above, which we can distinct thanks to HRTF. If you attenuate this to the level of being inaudible, you create a strange effect of ´looking through a window from a black-out room´.
If reverb in the listening room is kept sufficiently diffuse, not overly dominant in level, and of similar tonal balance compared to the direct sound and reverb in the recording, a pretty good compromise is possible.
The question is how to achieve this. Diffusion in the room, suppressing early discrete reflections, while keeping all indirect sound tonally balanced, are certainly a good starting point.
Sounds very very promising, but controlling directivity over vast frequency bands, is really very difficult.
If I recall it correctly, I know such planar transducer, companies like PS Audio and Radian using units with surprisingly similar geometry yet own diaphragm/drive structure.
The structure of the holes is almost irrelevant, as the geometry of the diaphragm and array of holes is creating a homogeneous wavefront anyways. That becomes a problem due to the sheer size of the diaphragm, which is causing a planar wavefront with usable listening window narrowing towards higher frequencies, particularly vertically, as expected from a truncated linesource. As the diaphragm is also pretty broad at the same time, you have a threshold frequency above which the directivity index is skyrocketing and horizontal listening window narrowing down as well.
If you want to design anything resembling a constant directivity concept with such driver, turning it into a midrange and keeping the passband pretty narrow seems to be a solution. For example PS Audio are using such transducers from approx. 500 to 2,500Hz which are surprisingly low crossover frequencies (
@Chris Brunhaver seemingly is a member here, maybe he might want to share his thoughts behind it). The problem how to combine it seamlessly with a tweeter, stays unsolved.
The other question is if you want to operate such planar magnetostat as a true dipole, or put it in an enclosure. From practical experience, I do not see much point to use a dipole here, as the sound emanating to the rear, under usual living conditions is hitting a wall quickly, contributing to a lot of early reflections hence significantly reducing critical listening distance.
