pianolover
- Joined
- Apr 22, 2022
- Messages
- 8
- Likes
- 2
Why are you sad, dear?Sad.
Interesting that you should mention that: I use aBit of a pointless product nowadays, may as well use an old laptop and a $100 Topping DAC for better measurement results and more convenience. (Rip CD's losslessly to your laptop and then check that they are bit-perfect using PerfectTunes. Plus you can stream losslessly if you want, etc.)
Yes there are... plenty of us too. The demise of physical formats is affecting the availability of historical titles on any given streaming service, both audio and video. Eventually old physical copies is all that will be left of some music, including vinyl.It seems there are still people listening to CDs.
That test (tascam) is from the analogue output, not the digital.And it shows the same strange harmonics at its digital output, which were not in the original file. These are most probably in the file burned onto the CD. But I leave this to @Rja4000 to explain, as he seemed to have found the reason.
That's true, but the shown harmonics are still not from the Tascam's DAC. You'll see.That test (tascam) is from the analogue output, not the digital.
Cool - I look forward to the explanation. Am I correct you are suggesting that something happens to the file as it is written to CD?That's true, but the shown harmonics are still not from the Tascam's DAC. You'll see.
I'll explain this evening. Working now.Cool - I look forward to the explanation. Am I correct you are suggesting that something happens to the file as it is written to CD?
I'm not trying to be "elitist", I'm just trying to be sensible. Vs this reviewed CD Player, you can get better performance / more portability / save money / and get more convenience by ripping CD's and then playing them back through a cheap but good measuring DAC (you'd choose a good measuring one that Amir has measured). So it's not "elitism", instead it's just good sense.Interesting that you should mention that: I use a
2011 Dell studio XPS (16") 1045 Laptop with Intel Core i7 940XM @ 3.88GHz, 8.00GB Dual-Channel DDR3 @664MHz (10-10-10-24), 931GB Samsung SSD 840 EVO 1TB (SATA), Optical Drive: MATSHITA BD-RE UJ235A
I can play Blu-ray, DVD, CD (and a few other formats through it) for on it's own screen or out put it through the HDMI port to larger screens.
This works very well for me when I am at sea for weeks at a time or on islands in the Indian Ocean or Western Pacific. Or the may places I go within the USA that do not have cell phone coverage, much less streaming capabilities (but are my preferred places to be).
One shouldn't presume that everyone lives and operates in a place that streaming is best & that old laptops are bad.
I am sorry (& maybe it isn't true) but what you say here sounds quite ELITIST to me.
I find this interesting. Digital downloaded music had only a four-year heyday. CD, on the other hand, over twenty years of heyday.I was always into digital downloaded music.
audiosciencereview.com
Maybee good sense, but there are other considerations than good sense. Playing Vinyl has not much with sense to do, but many likes the format. I think many who plays CDs also stream music, but from time to time plays CDs just because they like to do so. It is a different thing to pick a CD from a shelf compared to pick an album from an harddrive. But my initial post here was not about playing CD:s but about reasons to buy and collect CD:s I buy CDs, rip them, but also play them in a CD-player.I'm not trying to be "elitist", I'm just trying to be sensible. Vs this reviewed CD Player, you can get better performance / more portability / save money / and get more convenience by ripping CD's and then playing them back through a cheap but good measuring DAC (you'd choose a good measuring one that Amir has measured). So it's not "elitism", instead it's just good sense.
Excellent work. And I'm guessing the volume levelling will be what is causing the distortion. I suspect it is applying non linear dynamic compression to the signal. The distortion you saw on the first CD does look very similar to that on Amir's test from the digital output.I gave it a try : I burned my own test CD
Follow-up of this post.
Remember:
After a few trials, I was confused by the following:
When measuring SINAD from a track on CD, played through optical SPDIF output, I got this:
which shows unexplained distortions.
Then I measured playing the original wav file from a USB stick on the same player, also played through optical SPDIF output, and got this:
and I said I didn't understandw why such a difference.
Next logical step was to RIP the file back from CD
Importing the file in my measurement software gave me this:
while the original file was
Bottom line:
The distortion is on the CD !
How come ?
I burned the CD with what I had at hand:
An old Windows 7 PC with Windows Media player
Unfortunately, that seems to be the reason:
In WMP, the default setting are set for
Burn speed : Highest
and
Apply volume leveling accross tracks
So I just retried by setting Burn speed to Medium and unticking Volume Leveling.
So I burned the CD again
Then Ripped the file back to check
New Riped file:
Seems quite comparable to Original now.
And then, from this new CD with my NAD M50 CD player's optical output
There are some tiny differences due to the fact my measurement software doesn't use exactly the same parameters for reading a static file or reading from an ASIO input, but they are basically identical.
And there is no distortion anymore !
So what happened ?
I think WMP, when performing volume leveling (I burned 80 tracks on my CD at once) modified the file and re-applied 16 bits dithering on tracks that already had it.
NB: Of course, I have no clue if @amirm CD has a similar issue.
Re-measure of CD Players
Philips CD604
Optical output
Seems better, doesn't it ?
Now
SINAD from Philips CD604 Analog output (DAC)
Ouch !
But now, we know for sure the CD player's DAC is the guilty.
Other considerations about dithering
16 bits dithering is an interesting topic.
When we test for best perfomance, we usually use 24 bits format, of course.
With 24 bits, dithering is typically way below the hardware noise floor
(DAC's or ADC's best measured values are around -120dB, maybe -130dB. Dithering is at -146dB or so)
So we don't realize if the test signal we're using has dithering applied correctly or not.
But at 16 bits dithering, that's a different story.
And I could see differences between softwares.
The software I'm using (Virtins Mutli Instrument) seems to apply dithering differently than Audio Precision or REW.
It can produce better SNR, but higher distortion.
Also, it applies dithering whan using WAV files as test signal (which is very handy to run the AP Multitone, as an example).
But, again, re-applying dithering on an already ditheredwav file brings problems.
(I immediately used those new learnings to update my review and mesurements of the (16 bits) SONY PCM-R300 DAT recorder)
I learned a few things today.
Thanks to @amirm for this interesting CD review, that triggered those discussions.
Thanks also to @MC_RME , who challenged me (and others) on the distortion in the test signals.
Great post. Thank you!I gave it a try : I burned my own test CD
Remember:
That's a massive 15 dB improvement on THD
and I said I didn't understand why such a difference.
Bottom line:
How come ?
and
New Riped file:
So what happened ?
Philips CD604
Optical output
Now
Ouch !
Yes, people can enjoy the ritual of the physical CD process: storing them on a shelf, browsing through them & choosing one to listen to, maybe enjoying the tray mechanism of the CD player, looking at the CD cover art & reading the sleeves. So I can sort of see why people would do it, but for me it's a bit flowery and non-descript. At least the reviewed CD player here only costs $279 vs the EUR 2299 of the other CD player that was reviewed here a day or two ago!Maybee good sense, but there are other considerations than good sense. Playing Vinyl has not much with sense to do, but many likes the format. I think many who plays CDs also stream music, but from time to time plays CDs just because they like to do so. It is a different thing to pick a CD from a shelf compared to pick an album from an harddrive. But my initial post here was not about playing CD:s but about reasons to buy and collect CD:s I buy CDs, rip them, but also play them in a CD-player.
Thanks for asking. Because somebody is selling a €15300 CD player, which implies that people are buying a €15300 CD player. That makes me sad.Why are you sad, dear?
Most people can't hear below -35 or so. ;DYou cannot hear the difference in -100 db and -80 db distortion.
I wish vinyl fans realized they can enjoy the physical ritual (with CDs) without the sound quality losses of vinyl. Sincerely, someone that has ~400 records (DJ use) and ~500 CDS in a 350sqft apartment.Yes, people can enjoy the ritual of the physical CD process: storing them on a shelf, browsing through them & choosing one to listen to, maybe enjoying the tray mechanism of the CD player, looking at the CD cover art & reading the sleeves.
I do both. They are not the same.I wish vinyl fans realized they can enjoy the physical ritual (with CDs) without the sound quality losses of vinyl. Sincerely, someone that has ~400 records (DJ use) and ~500 CDS in a 350sqft apartment.
I don’t know, <$200USD? Play to DAC would be the minimum requirement for me at (near?) full 16-bit decoding/accuracy (ripping is an added bonus).What would a reasonable price? Does it need to play to a DAC or just allow ripping to a computer?
