Cavern QuickEQ - Basic How to
You can change both in the settings, and you should, because the frequency domain gets a lower resolution if you only increase the sampling rate.
Thanks. Please can you suggest which convolution lengths to match with which sample rates, or point me to the information?
I found some info on this over here: https://community.roonlabs.com/t/a-...w-and-rephase-using-convolution-filters/90990
I'll go with this until I learn more
Load the filter into a tool like audacity and look at the waveform, if the filter is minimum phase the peak will be at the beginning and if it is linear phase the peak will be somewhere in the middle, then look at the samples, I expect that you will find a lot of silence - zeroes in the filter. For example if it 64000 samples at 44.1k that implies you have over a second of echo in your room. If you have you should probably look at damping that before you try room correction, it can only do so much...
In the SqueezeDSP plugin that I wrote, it does a clean-up of impulse filters by scanning for samples below -70dbFS before and after the impulse and trimming them (this is a bit of a simplification) . Doing this on FIR filters that I had created using Cavern QuickEQ and REW resulted in impulses that were about a third their original size - without affecting the outcome - i.e all those zero samples have no effect on the audio and if your filter impulse is mainly silence you are making the convolver do a lot of unnecessary work.
This is correct, you will need a multiplier of the sample rate. First, decide what frequency resolution you need. The resolution is sample count divided by sample rate. If you need at least 1 Hz like I do, simply choose the first sample count option that's more than your sample rate.
For 192kHz sample rate, is convolution filter length 131072 sufficient (i.e. the maximum on your slider)?
With respect, VoidX gave the wrong equation. It's actually sample rate / taps; Fs/n.
So for your question, 192000/131072 = bin width 1.46Hz.
The question is why you need 192kHz. If you have so many taps running at those high rates, you can potentially run into problems with buffer starvation which will result in audio dropouts. That's why I don't use high sample rates. 48kHz is all that you need. At 48kHz, 65536 taps gives you a bin width of 0.68Hz.
Thank you for clarifying. I will do some more homework.
The vast majority of my music collection comprises 44.1kHz FLACs ripped from my CDs, which I am very happy with, but I have picked up a few higher res albums along the way, so was just hoping to cover all bases for a seamless ride. I suppose I could downsample those if it is a problem.
can you explain how to calibrate multi subwoofer ? i have 2 sub, and have you plan support macOS ? thanks sir :D
Just set up which output is wired to a sub, enable spatial remapping, and they're automatically calibrated, plus the remaining channels are automatically mixed to your layout.
Because of Apple's greed, releasing on a Mac costs $99 a year plus a Mac. If anyone pays this, there will be a Mac version.
They charge you $99 a year even though you release free software?!?!?
I’d like to ask one more question. Should I let the AVR handle the bass management, or would it be better to let the equalizer handle it? And why is there no crossover when exporting to CamillaDSP? many tks
For the perfect result with a PC, the measurement is 3 rounds: first, export the crossovers with Cavern, then calibrate with them on the AVR, and then do a final full Cavern without crossover on PC. This preserves the most dynamic range.
CamillaDSP is only present as a convolution target, not a full EQ target. Convolution filters are mono and can't hold crossovers.
