stakkallapelli
- Joined
- Jun 9, 2023
- Messages
- 14
- Likes
- 5
Would someone who has heard the CAT series of preamps let me know how they compare to Threshold preamps, namely the Fet 10 series or an SL10. I can't find any CAT dealers up here in the northeast area so there's no real opportunity for direct listening. For context, this Sl10 unit is used in a phono-only setup, with a Stanton 881s mounted to a Basis TT, a Threshold S/500, and a pair of Sound Labs. Musical preference ranges classical piano, opera, jazz, and large orchestral pieces. The SL10 has the following updates:
Thanks for your input and pardon the vague scenario and request. Once again, reason for this post is that there's no CAT dealer that I know of in the region so no opportunity for direct listening impressions.
- All electrolytic capacitors in the preamp module were changed for Elna Silmic II capacitors
- The resistors in the phono input section were changed to Vishay Dale metal film
- All RCA input jacks were replaced with gold plated copper units
- The volume potentiometer was replaced with an Alps BLUE
- All input/output wiring replaced with foamed teflon insulated Single Crystal continuous cast oxygen free copper wire
- The balance control was taken out of the circuit.
- Electrolytics in the power supply were replaced with high quality units of higher capacitance (this went up from 13,800 mF to 24,000 mF)
- The diodes in the power supply were replaced with ultra fast soft recovery hex fred
- The connecting cable between power supply and preamp was upgraded with higher AWG teflon insulated pure copper wire.
- The IEC connector was replaced with a gold plated copper unit.
