[Introduction] Hello ASR community. I’ve been working on a project to push the measurement limits of a home environment, focusing on how far consumer gear can go when the electrical environment is fully optimized. I wanted to share a milestone achieved using my Yamaha Montage M as the source, connected to a Focusrite Scarlett 16i16 (4th Gen).
[The Achievement] To establish a pure source signal, I utilized the Montage M's onboard ANX (Analog Physical Modeling) engine to generate a 1kHz sine wave. This allowed me to test the instrument's output stages at their peak potential. To ensure measurement integrity, both the Montage M and the Scarlett 16i16 were operated at a matched 48kHz sampling rate. Furthermore, by using the OCXO-stabilized Scarlett as the recording master, I aimed to capture the Montage’s analog output with the highest possible timing precision and minimal aliasing.
- SNR (Z-weighted / Flat): 93.77 dB
- THD+N: 0.00052%
- Noise Floor: Stable below -140dB across the audible spectrum.
I achieved this through two main pillars:
- Optimization of power supply and grounding: A systematic overhaul of the power delivery and grounding topology across the entire chain to eliminate common-mode noise and ground loops.
- Master clock synchronization: Integration of an 8663 OCXO as the master clock for the Scarlett 16i16. While the Montage M does not accept external clock input, stabilizing the recording interface's time domain with a high-precision reference was crucial for capturing the instrument's analog output with maximum phase integrity.
[The Road to >100dB] I am currently finalizing a formal academic paper that details the specific schematics and grounding methodologies used here. To maintain the integrity of my upcoming publication, I cannot share the full technical details just yet, but I wanted to demonstrate what is possible even with a consumer interface.
My next goal is to solve current challenges involving interconnect shielding and further power isolation to reach >100dB SNR (Flat/Z-weighted) before the final paper submission. I look forward to sharing the full methodology with this community once published!
I will try to answer as many technical questions as possible, but please understand some details are reserved for my upcoming paper. Happy to discuss the results!
