Carver PT-2400 Dual Mono Vintage Amplifier Review
Rate this amplifier:
    Votes: 36 22.4%
    Votes: 85 52.8%
    Votes: 35 21.7%
    Votes: 5 3.1%
This is a review and detailed measurements of the Carver PT-2400 dual mono power amplifier. It is on kind loan from a member and cost US $2,400 when announced in 1991.
Carver PT-2400 rack mounted vintage stereo dual mono power amplifier review.jpg
The amplifier came in both consumer (TFM-75) and professional versions. This pro version seems to have taken the consumer version and encased in thick sheet metal. I expected it to be light like my Carver amplifier but it is quite heavy. It has all the features of a pro amplifier include a fan that runs all the time:
Carver PT-2400 rack mounted vintage stereo dual mono power amplifier balanced back panel review.jpg
As you see, it has dual 12-amp IEC inputs. I only have one circuit on my bench so resorted to testing just channel 1.
The amp was professionally restored by a Carver employee. It worked solidly in my testing, with case temps remaining at room temperature. The aforementioned fan makes a low frequency hum that is not too loud due to its large size.
Carver PT-2400 Amplifier Measurements
At max sensitivity, it delivers 33 dB of gain. To make things more of a level playing field, I dialed that down to about 22 dB:
Carver PT-2400 rack mounted vintage stereo dual mono power amplifier measurement.png
I was disappointed by the spray of harmonics which delivers performance below the bottom quartile of all amplifiers tested:
Noise performance is not great at 5 watts but gets much better at full power (meaning noise is mostly static):
Carver PT-2400 rack mounted vintage stereo dual mono power amplifier SNR measurement.png
Carver PT-2400 rack mounted vintage stereo dual mono power amplifier SNR Max power measurement.png
The rail switching architecture likely requires an output filter which may be responsible for some frequency roll off and small load dependency:
Carver PT-2400 rack mounted vintage stereo dual mono power amplifier frequency response measur...png
Distortion as expected, hurts multitone performance:
Carver PT-2400 rack mounted vintage stereo dual mono power amplifier Multitone measurement.png
Although not too bad compared to today's Pro amps.
Name of the game here is power and the PT-2400 delivers a ton of it:
Carver PT-2400 rack mounted vintage stereo dual mono power amplifier Power 4 ohm measurement.png
Carver PT-2400 rack mounted vintage stereo dual mono power amplifier Power 8 ohm measurement.png
We can see the jump in distortion when the output transistor rail voltages are increased. Keeping the voltage low at lower power levels reduces idle power consumption and hence heat generated but has that price.
Good to see some headroom still:
Carver PT-2400 rack mounted vintage stereo dual mono power amplifier max peak Power 4 ohm meas...png
Peak power at 40 Hz breaks records:
Sweeping at different frequencies we see that high frequencies get even more distorted, similar to class D amps:
Carver PT-2400 rack mounted vintage stereo dual mono power amplifier Power 8 ohm vs frequency ...png
The amp is essentially stable on power up:
Carver PT-2400 rack mounted vintage stereo dual mono power amplifier warm up measurement.png
Power on noise is the highest I have measured so expect some noise when turning it on:
Carver PT-2400 rack mounted vintage stereo dual mono power amplifier on off pop noise measurem...png
The PT-2400 lacks linearity as evidenced by high distortion. It is however, quite powerful and keeps up with modern professional amplifiers. I don't know how much it costs to get it refurbished on top of purchase price -- likely much higher than today's pro amplifier. In that regard, it only makes sense if you value its nostalgic value. Performance wise it doesn't bring much to the table.
Google AI Gemini spec sheet:
Core Specifications
    • Stereo Power Output: 750 watts per channel into 8 ohms, 1200 watts per channel into 4 ohms.
    • Mono Power Output (Bridged): 2400 watts into 8 ohms.
    • Frequency Response: 20 Hz to 20 kHz (±0, -0.5 dB).
    • Total Harmonic Distortion (THD): <0.5%.
    • Signal-to-Noise Ratio: >100 dB (rated power into 4 ohms).
    • Damping Factor: >200 at 1 kHz.
    • Physical Profile: 3U Rackmount chassis weighting approximately 46 lbs (20.9 kg).
Key Features
    • True Dual-Mono Architecture: Built as an independent dual-source design. It features two entirely separate power supplies, which even extends to requiring dual independent AC power cords to ensure full current delivery under punishing loads. [1, 2, 3, 4]
    • Clipping Eliminator Circuit: Includes a built-in clipping prevention mechanism that keeps the output clean and undistorted even when overdriven by up to 8 dB. [1]
    • Professional Connectivity: Features balanced XLR inputs alongside barrier strip inputs for permanent installations. Output is handled via standard heavy-duty 5-way binding posts. [1, 2]
    • Active Cooling: Employs a continuous rear-to-front airflow design with an integrated, serviceable foam dust filter to protect internal components during long operations. [1, 2]
Thanks Amir for another very interesting review! The results are likely expected for a power amp designed for professional sound reinforcement where the priorities of high power, durability and solid reliability are considered more important than very low distortion and noiseless operation.
As not all amps of this sort have an anticlipping circuit I wish that feature would have also been included in your testing - especially since I believe that Carver's use of an anticlipping circuit may have been involved in some threatened or actual legal action from McIntosh.
Re the Gemini derived spec sheet: I have found Gemini to often make significant mistakes in reporting the specs and basic configuration of several pieces of audio gear - even quite recently. These errors seem to be most prevalent in gear sold before the mid '90s.
Amir, you mentioned it’s heavier than your Carver. I’m curious to know which model do you own?
I voted poor. For big power yet still low noise and distortion I would get an NC2k based amp.
I remember the days when Carver amps were something to lust after. It appears my desires were quite misplaced.
Today’s modern, Class D are powerful, clean and economical. These new marvels, based on Hypex or Purifi boards, make me blush.
Once again, Amir proves that we are living in a new reality for hi-fi. Enjoy it.
Is anyone here going to argue that the distortion of the relic isn't sufficient to produce an audible difference versus current ultra-low distortion amplifiers? I hope not.
Its distortion, particularly its high level of high-order harmonics will render it a pretty nasty listen.
The PT-2400 is basically a PA amp. The manual data show that it's THD is not in the 0.001 range. So I think it was made for high power and reliability which is shown by the 2x mono construction. Not specifically for HiFi usage. This is also stated by usage of a fan which can be noisy. Therefore I can't put much blame on it.
That was roughly my thoughts reading the review too. Picture it in beefy racks with castors off stage or behind the monster speaker stacks ruining your hearing at the clubs you visited in the early 90s. Looks like solid performance for that job. That level of distortion wouldn't have been a problem. Putting its SINAD in a diagram mostly full of modern hi-fi amps is not quite ... idk ... relevant?
How it compares with modern kilowatt PA amps would interest me. I recall a few have been reviewed here but haven't searched for them.
For pro use I think you'd be better off going Crown or Behringer, for domestic I'd expect it to have slightly rough and dull sound.
I doubt the "distortion" would be audible in normal usage. The internals are a bit messy compared to modern gear for sure. Power wise, this thing is a beast! I rated it as "Fine".
It's 1991 tech though, not bad for the time.
Thanks for the pics, JSmith. I like the look of the cooling design. I'd guess the fan draws air from what looks like a filter on the front panel through the channels between the heat sink fins.
On the other hand, judging from Amir's picture it doesn't look easy to access the inlet filter for cleaning or replacement.
Bob Carver said he could make a solid state amp sound like a tube amp, and given these high noise and distortion measurements, it looks like it was achieved that with this amp. Good thing I couldn’t afford such an amp back then.
Today’s modern, Class D are powerful, clean and economical. These new marvels. based on Hypex or Purifi boards make me blush.
I hadn’t thought about Carver amps in years and this review made me take a trip down memory lane.
A buddy in college (who always seemed to have too much money for a college kid) had a pair of Carver M-400s. He would occasionally DJ keg parties so that was his excuse to buy them.
I think he had some big Cerwin Vegas on the other end.
These little Carver cubes always stood out in the crowd.
While I was quite proud of my Harmon Kardon Citation pumping out sixty whole watts, these Carvers were rated at 200 into 8R (x 2) or 500 W into 8R mono. Those numbers were something from another world in the late 70’s/ early 80’s.
My how things have changed!
