I have post a ton. Others have too.This site has many demands for controlled listening tests. Are there links to the threads where they've been done?
Is there a sub forum for that or is it just a search around kind of thing? I'll poke around.I have post a ton. Others have too.
If only that were true! It might be in a logical world, but unfortunately, although humans are an intelligent species, we are not necessarily a logical species. Indeed, we are so abundantly illogical that the discussion of topics such as climate change and Covid-19 are forbidden because of the illogical controversies based on vehement anti-science stance of many folks.Before you can have a preference you need to be able to reliably tell the amps apart.
For all the talk about preferring this amp over that amp and the merits of measurements versus listening I see little proof anyone can reliably tell any of the mentioned amps apart in a controlled test. Before you can have a preference you need to be able to reliably tell the amps apart. It seems like this step gets skipped over which makes subjective preferences useless to learn anything from.
@levimax did it with a Stereo 70.This site has many demands for controlled listening tests. Are there links to the threads where they've been done?
Mostly for extraordinary claims. For stuff that not unexpected, say frequency response differences or signal manipulation (e.g., DSP) or other things ears are actually sensitive to, there's far less burden of proof expected.This site has many demands for controlled listening tests. Are there links to the threads where they've been done?
I think for many, including me, the most salient point and the entire 'justification' is simply that vacuum tube amplifiers are more entertaining to look at and appreciate as objects. There's really no further justification needed. If that doesn't register with a particular buyer, they should simply stick to solid state. And of story.For all the talk about preferring this amp over that amp and the merits of measurements versus listening I see little proof anyone can reliably tell any of the mentioned amps apart in a controlled test. Before you can have a preference you need to be able to reliably tell the amps apart. It seems like this step gets skipped over which makes subjective preferences useless to learn anything from.
Thanks for the link. I find such tests very interesting to read about but there aren't a lot of them that I've seen documented (not that it was a very thorough search).Yes, because bias is a thing.
I'm sure your eyes roll more than most, after you actually bothered to do one with your amps.
They are scattered around. What's missing are the ones that demonstrate the claimed differences. After my one experience testing myself, I thought I'd actually learn what all those numbers mean so I could leave the reliance on magic woo behind.
After a few months of doing a lot of reading around the place, much of it about psychoacoustics, I was pretty well de-woo'd.
Here's one:
Post in thread 'If "Tube Sound" Is a Myth, Why Tubes?' https://audiosciencereview.com/foru...be-sound-is-a-myth-why-tubes.8656/post-548462
I agree completely and you are always clear about the reasons for your preference for tubes, I enjoy them as well. I get a little frustrated when people either talk about how "terrible" tube amps sound based on measurements or how "magical" tube amps sound based on sighted listening. In my experience unless something is broken or used outside of it's range amps are very difficult to tell apart. I think the real lesson is people don't hear nearly as well as they think they can and SINAD of 60 or possibly even 40 is good enough for most music.I think for many, including me, the most salient point and the entire 'justification' is simply that vacuum tube amplifiers are more entertaining to look at and appreciate as objects. There's really no further justification needed. If that doesn't register with a particular buyer, they should simply stick to solid state. And of story.
I honestly cannot for the life of me believe that this even a point of debate, because as humans (most of us anyway), we are subjective in most things we encounter, and nothing is going to change that, at least until we are all robots in the likeness of Jeff Bezos.
Not this again. I've owned several tube amps and listened for years. So have many here. It's not that we've never heard them. But at best if they sound different it's a coloration. If you like it then fine.It's clear that many here are not that familiar with tube amplification. The notion that listeners of tube equipment are doing so out of a love for distortion or because they are mesmerized by the glow of the tubes or feel special because they do or whatever... it's all grossly misinformed generalizations. There is no shortage of internet threads debating tubes vs solid state that would make a 70-pager seem like a cursory summary, it seems quite out of place in this thread. Those that subscribe to such beliefs that are posting on a site where they seek clinical tests to validate their own listening preferences should consider their own blind dogma and get out and listen more...
Ouch. I try to do a post-mortem on amps that I work on. This is typically impossible. I usually just assume that if the output is blown, it somehow got shorted at the binding posts. Not so sure here. Your failure sounds similar to the amp I repaired: shorted output transistors including base shorts, emitter resistors blown to pieces ... but nothing burned in my case. I guess in your case the burning is from the emitter resistors, they held up where mine blew? Just a guess. Burning on PCB can indeed be challenging to fix, especially with dual sided PCB as these amps have. I'm not a materials guy but it's possible the carbon created from burning fr4 could add some level of conductivity where previously none existed? Both rails are fused on each channel. The fuses are 15A. This seems far too high to prevent any speaker damage. One was blown in my case. It probably did prevent blown out PCB traces, but not much else. I now better understand your comment regarding "reliability (or safety)".My tech's summary statement from July. I should probably just send it to e-waste heaven...
"...one channel has shorted outputs, unfortunately it damaged everything behind them even burnt the board. They don't short collector to base very often but it's a good thing they did otherwise your speaker would have gotten the rail voltage."
But that's true of any audio device, whether tubes or SS.Not this again. I've owned several tube amps and listened for years. So have many here. It's not that we've never heard them. But at best if they sound different it's a coloration. If you like it then fine.
Anyone of my age will have been very familiar with valve amplification, as that's all there was! There's no dispute possible that valve amplification is inferior to solid state in frequency response, distortion and noise, not least power consumption, although the better ones are good enough for transparency so with those, there's no audible difference, and therefore no reason to have them except for the attractive looks.It's clear that many here are not that familiar with tube amplification. The notion that listeners of tube equipment are doing so out of a love for distortion or because they are mesmerized by the glow of the tubes or feel special because they do or whatever... it's all grossly misinformed generalizations. There is no shortage of internet threads debating tubes vs solid state that would make a 70-pager seem like a cursory summary, it seems quite out of place in this thread. Those that subscribe to such beliefs that are posting on a site where they seek clinical tests to validate their own listening preferences should consider their own blind dogma and get out and listen more...
I'm not sure that I agree about 'which is the case for modern amplifiers'; most of them I've encountered are not. But I have encountered a few; IMO what this seems to come down to is exactly how low the distortion actually has to be before its masked- and that is lower than many think. This is entirely due to the fact that the ear uses the higher ordered harmonics to sense sound pressure, so if the amp adds any of its own, it can be detected. In a nutshell we've been hearing this for the last 50 years and most of it simply has to do with the simple fact (or maybe not so simple) that most amps simply lack the gain bandwidth product needed to really control distortion. If you graph distortion vs frequency then you see how this bears out; it can be a mistake to only look at the distortion curve at one (usually low, like 100Hz) frequency. Almost any amp with feedback has enough feedback at 100HzSerious question: if all harmonics are below any reasonable audible threshold (which is the case for modern amplifiers), what needs to be "masked"?
The Sunn is in no way similar to your Pass amp. It employs a driver transformer and so is not a wide bandwidth device nor is it low distortion or class A and it has a push-pull output. I only mentioned it because of its prodigious 2nd harmonic which the ear interprets as 'warmth', 'lush', 'rich'; all audiophile terms for audible 2nd harmonic.What an interesting post. I don't know if you'd know the answer but would that Sunn amp be similar to my Pass Aleph 30, which also is single ended solid state and low/zero feedback? I ask as it is, of all the solid state amps I've heard, the one that reminds me most of how tube amps sound. It would certainly not measure in the top of amps here but its an enjoyable thing (to me) to throw in a system every once in awhile here.
Beautiful amp! Amazing price - I look forward to hearing your impressions of it.
Although I was initially attracted to the looks of the Carver Crimson amplifier, it never made my short list because of a low perceived price/value. I believe that this YarLand amp will prove to be a much better price/performance value, and have started a thread here at ASR to document my journey with this, likely my last "exotic" amplifier. (I cross-posted and edited some segments of this comment in the YarLand thread.)
I look forward basking in the glow of the tubes as I listen to my collection of high bit-rate VBR MP3's, which includes the 63 album collection of the Chicago Symphony Orchestra from the Fritz Reiner era of the 1950's and 60's. I was an usher for the CSO during my high school days in 1957-58, so some of those albums are from performances for which I was an usher.
I have rational reasons (including nostalgia and manufacturer reputation) for buying this amplifier, which is on its way to me in Panama from China via Miami. YarLand/Ariand amplifiers were fairly popular in Europe over the past coupe of decades, with power transformer customization and other mods being done in the U.K. and Italy by distributors. They received good (subjective) reviews for sound and build quality. My Model FV-34B-S amp uses the classic EL34 output tubes and 6SN7 drivers in a push-pull Class-A design, although I would have preferred Class-AB design for better tube life and lower power consumption. This amplifier has a pair of stereo balanced XLR inputs, which is very rare in budget-priced tube amplifiers. It is also switchable from triode to pentode operation, and specs in general are decent for a tube amplifier. (There are some discrepancies between the specs, photos and description, so I will not know some of the details for sure until I receive it.) Because of the general bad reputation of stock unbranded generic tubes shipped with many Chinese amps, I do plan to immediately replace the EL34's with 6CA7's, and get new 6SN7's, both Electro Harmonix from Viva Tubes, and very reasonably priced. The replacement input tube will be a NOS GE-JAN 5670, which costs $4.79 each on eBay. Good quality audio vacuum tubes are not always outrageously priced, thanks to the sales volume supported by the guitar amplifier world. Of course, guitar players buy them to drive into distortion, and Hi-Fi audio tube fans buy them to use below gross over-driven distortion levels.
If I weren't 80 years old and getting towards the end of my days, I would have sent it to Amir for testing - just for fun, because I would not expect stellar results. (There is one of this model plus a couple of other models still left from this apparently shut-down manufacturer via China Hi-Fi Audio, so someone else can buy the last one for $753, and drop-ship it to Amir for testing and measurement! )
