Cartridge w/ very high compliance (curiosity only)
The SME III damper (and its FD200 sibling) was far too severe - just hold the headshell over a record and let go - the stylus descended not too differently to the cueing device!!! Either use the smallest paddle shaved to a pencil point, or better, use baby oil or similar, instead of the goo that SME originally supplied!
If you have a company that can properly re-tip your 881S with a decent Shibata-type diamond (rather than a new cantilever/diamond assembly as most do), I'd suggest considering this, as a good 881S sample was seriously good back then and fine for the arm. Modern third party replace,ents may well alter the tonal balance as happens with Shures, which actually many people prefer, so there ya go!
Alternatively, I'm not sure if the III headshell (certainly the earlier version) can take the Ortofon 2M models (a Bronze or Black would be excellent sonic match and the 'Blue' would certainly spice up the reproduction a good bit), but if you patiently look around, the SME/Ortofon 'Concorde' arm wands, may come up and now, Ortofon have a whole new range of styli similar to the 2M range, which should fit the OM bodies too with luck (when my OM30 stylus finally gives up).
As for high compliance, I come from the days of the Empire 1000ZE/X and ADC 25 and 26, with impossibly high compliance styli that only seemed to work best back then, in the Transcriptors Fluid Arm at 0.7g or so, said arm a very low mass highly-damped uni-pivot type. Even the SME II Improved with fixed headshell wasn't quite right. I have an ADC 26 here and an original brand new XLM and neither work stably nor track securely at under a gramme in a typical mid-mass tonearm (could be age, or more recent 'hot-cut' pressings). My Shure V15T2 (new Shure stylus) is a compliant 1g tracker but it's not as 'wobbly' as the ADCs are. (The V15 III is definitely more tolerant here.)
The idea is to get the arm-cartridge resonance down to 10Hz or so and then filter it away below 20Hz in the phono stage. I hope @Frank Dernie can chip in from a turntable-engineer-of-old viewpoint please...
I have the series III ( 3 ) arm effective mass 5 grams , from the 2M series Bronze and Black has higher compliance than the rest of them .its the smallest damper paddle right now , I have ordered the rest of them . It’s suggested in the manual that you can have lower compliance cart with a bigger paddle, but maybe it’s wrong :) suppose mfg data can be wonky too ? Or do we have new knowledge nowadays ?
JICO’s 881 shibata replacement is no good then ?
