There can actually. My measurements are using Kelvin setup (4-wire) to remove the effect of the speaker cable for example. We are measuring pretty small values and even connection robustness can make a difference.Two things:
An impedance sweep is easy. Especially of a speaker. There shouldn’t be a noticeable difference between setups.
Regardless of all this, a difference of <0.4 Ohm wouldn't account for the measured difference in frequency response, anyway.
Are these things safe to use indoors as far as carbon monoxide and such?
I can appreciate that. We have a generator for that It is a beast and sits outside, powered by a GM industrial engine!One other thing vs electric. If you ever have a power outage then this is a godsend. More than once I was left without power in an ice storm.
bingo
My reply earlier was “is there a difference? I can’t tell, but it doesn’t look like it. If there is, that might explain things, though.”
that’s all I was trying to find out.
. You did not post the radar plot for F328Be. Can we see them side by side?
Carmody S2000 APO EQ 96000Hz
November132020-111537
Preamp: -4 dB
Filter 1: ON PK Fc 206 Hz Gain -2.22 dB Q 0.9
Filter 2: ON PK Fc 1140 Hz Gain -1.67 dB Q 2
Filter 3: ON PK Fc 1597 Hz Gain -1.67 dB Q 13.4
Filter 4: ON PK Fc 2595 Hz Gain -1.86 dB Q 6.54
Filter 5: ON PK Fc 3356 Hz Gain -2.23 dB Q 3.18
Filter 6: ON PK Fc 5128 Hz Gain 1.86 dB Q 2
Filter 7: ON PK Fc 9382 Hz Gain 3.3 dB Q 2.83
Filter 8: ON PK Fc 17454 Hz Gain 3.9 dB Q 4.47
I am assuming the tweeter response is so low just due to the designer going a tiny bit overboard in taming it. As even though is does rise up, the PIR curve shows it is a smidge too low
Good grief!!! Something is seriously wrong with the scoring system or my measurements of F328Be. Then again it demonstrates why I liked the sound of S2000.And the radar for @amirm
Something that doesn't jump out of the measurements and is a key reason I listen is power handling. Yes, I show you the distortion graphs but those are two points and you can't hear what I am hearing. In this case as I noted, the speaker incrementally gets louder and louder without falling apart like just about every budget speaker.
baltic birch
The estimated in-room response is good and ultimately that's what matters more than on-axis anechoic measurements, unless of course you live in an anechoic chamber.So, a speaker that measures significant flaws but sounds subjectively good in sighted listening to one person, gets a knocked-it-out-of-the-park panther.
Got it.
If I get super rich from this site one day , I can put a mini-split system in there.
Yes, I don't understand why. My brother lived in UK for a while and told me to get one of them years ago. When I told him how expensive they were here, he could not believe it. I had one installed for my woodshop and it cost $3,000 I think! He too said it cost 350 pounds or so to get one.USian mini-split prices are outrageouts. I paid 350€ + 60€ installation labor for a 12000 BTU inverter mini-split here (Greece).
Got it.
Hi AmirSomething that doesn't jump out of the measurements and is a key reason I listen is power handling.
ME: le me google:So, as long as you don't plan to listen to it above the mid-80's it would be OK. But that's some very high distortion, all things considered.
