Properly sized coupling caps are the key. Do that and it doesn't matter what the cap type is. I have piles of measurements demonstrating this over at my
website.
Here's an independent confirmation:
1. The setup schematic
- DUT is allegedly the worse electrolytic I was able to find in my junkbox. Got them brand new about 20 years ago at a liquidation, 25pcs. for $1 and never used any of them. They are polar 100uF/100V certainly of Eastern origin, no branding other than a big letter A in a thin frame.
- My setup is differential, so I inserted the cap on one of the branches.
- The ADC has the inputs isolated from the input stage common mode voltage (2.25V) by two bipolar Nichicon MUSE ES 47uF/16V electrolytics.
- The ADC differential mode load is 2.8K, which is at the low end of any audio appliance.
- DAC differential source impedance is 210ohm.
- Loop high pass cutoff frequency is about 2.4Hz. With the DUT in place is about 3.5Hz (calculated). In the 20Hz-20KHz frequency range, the setup FR drop is well under 0.1dB (see above).
2. Measurement setup
- ADC and DAC are both running @192KHz sampling rate. They are in sync mode (driven by the same clocks in slave mode).
- Differential voltage at the DAC output is about 2Vrms (-6dBFS)
- Frequency response of the loop: Note the Y scale is +/-0.1dB
- 10 harmonics are considered for THD. Since the bandwidth is limited to 96KHz, frequencies over 9KHz have less harmonics contributing to the THD, therefore the decaying THD towards 20KHz (see below).
- For both cases, the 3rd harmonic is dominant at low and mid frequencies. 2nd harmonic is at -135db at mid frequencies.
3. Measurement results:
- Red is the loop THD (with the DUT replaced by a SMA female-female through adapter) Orange is the THD with the DUT in place.
- The junk(?) Chinese cap adds 2-3dB of THD between 20 and 50Hz.
- I am quite suspicious about measurements below -120dB, since they are at the uncertainty limit of the setup. But assuming the LF distortion delta is real, I am not planning to lose my sleep over it.
- These chinese NOS caps could be successfully used in the most demanding audiophile appliances.
- I have no idea why the HF distortions of the cap are lower by about the same amount (compared to the loop).
That's it, folks. The myth of polar electrolytic distortions is once again debunked. Electrolytic distortions are a matter of proper design, and have almost nothing to do with the intrinsic properties of the devices. Pathological cases excluded, of course, I am sure High End Audio Priests could find electrolytics with euphonic distortions and sell them as a feature
