fpitas
Honestly if these subjectivist internet mavens ever chose a reasonably priced cap, especially from (say) an industrial offering like Panasonic has, I'd faint.
The final capacitor in the power supply - think B+ rails - is absolutely in the audio signal path.Most of the polarized capacitors that you find in audio equipment are for power supply filtering (not in the signal path).
Sure. But even if it's an electrolytic it's heavily polarized by the applied voltage, so negligible distortion. Also, if there's feedback in the amplifier that would tend to reduce any distortion from that cap.The final capacitor in the power supply - think B+ rails - is absolutely in the audio signal path.
The point is that cap has an effect on the linearity of the amp due to esr at a given frequency. It pays to look at the manufacturer spec sheets as esr is not always decreasing with frequency. Then verify that by testing your samples.Sure. But even if it's an electrolytic it's heavily polarized by the applied voltage, so negligible distortion.
That's true; that is all part of designing any amplifier.The point is that cap has an effect on the linearity of the amp due to esr at a given frequency. It pays to look at the manufacturer spec sheets as esr is not always decreasing with frequency. Then verify that by testing your samples.
I would never use and electrolyte as a coupling cap.
I did not mention distortion.ESR itself does't create harmonic distortions, it's voltage coefficient may.
Linearity as in frequency response. I was not speaking to harmonic distortionHuh? Linearity (or non, thereof) is anything but distortions effect?
My original reply was stating that the final cap on the B+ rails for a power amp output stage is in the signal path. The AC signal path is through the output devices in and out of your speakers and back through the last cap in your B+ supply. I am not talking about input capacitors. Depending on your output power and speaker inefficiency the AC current through that cap can be high at higher listening levels. Depending on your power supply design there also can be high ripple current at 120 HZ off the FWB. Using a dedicated film cap rated for long life at high ripple current from the FWB then use a regulator or choke between that cap and the final power supply cap will eliminate high ripple current on the final cap. Poor choice of that final cap affects frequency response and reliability.Ok, but I am pretty confident that extra few ohms ESR has virtually zero effect on the frequency response (or "linearity", as you put it) for any decent input impedance.
Example:
1k (which is already very low) input impedance with 100uF coupling capacitor has a 3dB corner frequency of about 1.6Hz. Adding 4ohm ESR *) moves the 3dB corner with -0.00634Hz and the attenuation at 20Hz changes from -0.0275452dB to -0.02732688db, a whopping -0.000218dB
If this is not laughable, I do not know what else is
*) Values are for the worst 6.3V electrolytic cap available on DigiKey with tan delta = 0.32 at 120Hz and 20 degrees Celsius. This tan delta value leads to ESR=Xc * tan delta = 4.2ohm
Where did you get the idea I was talking about tube amps? CLC filters can occur in any power supply. Schiit Tyr uses CLC. Do you not understand that all of the music signal goes through the last cap in the supply?Ok, have it your way. Call frequency response "linearity", then shift the focus to tube amplifier power supply design. Flashnews, the filter cap ESR is a non issue for any competent designed power supply, except perhaps SMPS's (which are not about LF ripple).
If ESR is a problem, then it is about an amplifier with zero or very low PSRR, quite typical in the high end audio realm.
Based on the number of assumptions you have made, I wonder if you actually have any respectful discussions with anyone.Because you mentioned above B+. Last time I've checked, this is the common denomination for tube amplifier power supply voltage.
I understand perfectly, and I maintain the effect of the last cap in the supply is virtually zero (except in pathologically bad designs). I don't give a Schiit if any manufacturer decides to use CLC in the SS amp power supply, to me that's a waste of money, space and weight. In particular thinking of the currents a SS amp is drawing a full power.
Come up with numbers if you want to bring anything relevant to the table. Otherwise, this discussion is over.
P.S. From the Schiit web site: 55 lbs. 12 lb choke. Insanity now has a name.
New deflection. Because you mentioned it, respect must be earned. So far, you failed miserably.Based on the number of assumptions you have made, I wonder if you actually have any respectful discussions with anyone.
