I am searching a dac/preamp for my main system.
And It is proving to be difficult. The hardest problem I am having is that measurements are not meaningful anymore.
Above a certain threshold it doesn't matter anymore. And according to here, they then all sound exactly the same. So it doesn't matter if you buy a dac of 100€ or 20000€ if they are above some measurements they will all sound exactly the same. This is where I cannot get my head around it.
So if you put 3/4 of the dac's tested here next to each other. There will be no difference in sound.
I have heard a few products (mind you not voltage levelled and such) and they sounded all different. Like for example I have a Grace Design m902 that I use to listen music through a headphone from the computer. If I plug the headphone in the computer directly then the sound is much different then if I plug it in the Grace Design. I know that I don't need to voltage level it because I literally hear details that are not there if plugged in the computer.
I just cannot wrap my head that there is just no difference in sound in 3/4 of the dacs tested here. Is that 100% the case?
I always am someone that how better the measurements how better the sound. But if that is not the case then I can buy the RME DAC and be done with it if I don't need other features.
So you guys are all saying that above certain measurements that the sound is 100% identical no difference in speed, imaging, etc...
It is twisting my head so much.
