Infinite100
- Joined
- Dec 28, 2023
- Messages
- 12
- Likes
- 6
Hello knowledgeable people.
I got my Audeze Maxwell, which atm I use in Bluetooth with the Alternative A2DP Driver, so I have LDAC.
I choose this over the supposedly (according to Audeze) preferable USB Dongle because the latter only supports 48000 and 96000, making the use of exclusive mode in Foobar complicated.
With the Alternative A2DP driver I can select all 4 sample rates, 44100, 4800, 88200 and 96000, so that the only case when I can't use exclusive mode is when I play 192000 files, in which case Foobar will automatically downsample to 96000.
So far so good.
But from what I understand there is another kind of resampling, mostly upsampling, that some people are fond of, = upsampling everything to 192000 or higher, to allegedly improve the sound.
In a comment on this website I've read that "Converting a digital (sampled) signal to a continuous analogue waveform requires interpolation to produce the values between sample points. Doing part of this interpolation digitally (upsampling) simplifies the analogue circuitry and gives better results. That's all there is to it. Whether software upsampling is audibly superior to that built into DAC chips is debatable.".
Now, please correct me if I am wrong, but from the mention of "digital to analog" I understand that the alleged benefit of upsampling is only when using cabled headphones/speakers, not when using Bluetooth or other wireless transmission (like the Mawwell's USB Dongle).
And I also guess that when I decide to be fancy and I use the Maxwell with an Enoaudio Mogami cable and the iFi GO Link (which has a ES9219MQ/Q Quad DAC+ with 32bit HyperStream III) the alleged benefits of upsampling will be rather questionable.
Is this correct?
In other words, I can just forget all this topic and let other people worry about how significant the advantage of upsampling might be in other cases?
Thanks
So far so good.
Is this correct?
Thanks
