Pdxwayne
- Joined
- Sep 15, 2020
- Messages
- 3,219
- Likes
- 1,172
I was able to hear a difference using AKG 371, but not easy at all. Got abx results of 8/8. Then one member said "everyone" can hear a difference. I asked the member to give abx result but I got none. The other member chimed in to support the first member and basically said science already supports that claim. I asked for abx from the second member and again was ignored.
[Update 3:. Both members responded. First member can hear a difference and can pass abx. Second member so far can't hear a difference.]
Would you please take a listen to the two files and tell me if you think "everyone" can hear a difference? Or, you think most people can't hear a difference?
You can just download and quickly listen and tell me your impressions. Of cause, it would be great if you can provide your abx results. Thanks!
Files are here:
Update:
I found out that using my speakers setup is very easy to tell a difference. The issue seems related to AKG 371.
Update 2:
Add what I have tried so far:
*AKG with Topping E30 and L30 - not obvious. Need to concentrate hard to get 8/8 abx.
*AKG with Samsung Note 9 phone - not obvious. Did not do ABX.
*$50 cheap headphones with Topping E30 and L30 - not obvious. Did not do abx.
*~$150 Andrew Jones designed Pioneer speakers with Topping chain, minidsp 2x4, and Parasound A23 amp - not obvious at all. Did not do abx.
*Laptop speakers - not obvious at all.
*Living room setup with Paradigm Persona B speakers - obvious. Can easily tell files apart. Did not do abx as family members are around. Quickly tried -70db down at 1250hz and can still sense a difference easier than when using AKG 371 to abx -60db down.
Update 4:
*AKG with Gustard X16 and H16, H16 at volume level 35, able to pass abx. 8/8. 1250hz barely noticeable, but good enough to pass abx.
Files are here:
250hz_h2_to_h4_120_h5_60.wav and 1 more file
2 files sent via WeTransfer, the simplest way to send your files around the world
we.tl
Update:
Update 2:
Update 4:
