Re BMR with less expensive drivers: I've been playing around with a few ideas to work on in my hopefully-soon retirement. One of them is a 3-way using the BMR and very inexpensive other drivers. Since the use-case would be for multichannel music and Auro 3d upmixing though a Denon X-4700, the efficiency target is around 90 dB after baffle step (there isn't much power available if you are using all 9 channels of amplification).
Drivers: Techtonic TEBM46C20N, Peerless FSL-0615R02 vented 15 liters (Denovo cabinet) f3 78 Hz, Peerless DX25TG59-04 (or
BC25TG15-04 if it goes low enough with a resonance comp circuit). I plan on experimenting with the following: 1) a crossover loosely based on a Duelund where the mid level is about 4dB below the woofer and tweeter but sums flat. 2) with and without a shallow modeling clay waveguide on the tweeter. 3) With and without dual chamber reflex. I do not know how much BMR "flavor" the mids would have but the -6dB directivity should be very good. Will need a sub or two. Unfortunately, this will be a lot of work and will have to wait for my retirement.
