Hi everyone,
I’ve been working on a project called
vinyl-check and I think this forum is probably one of the best places to get the methodology challenged properly.
The basic question behind it is:
How much of vinyl playback quality can actually be measured from the captured audio signal instead of being judged purely by listening?
vinyl-check records a side of a record through an audio interface and analyzes the resulting audio locally.
The project currently covers three main areas:
1. Record condition / defect detection
The software detects transient defects such as:
It then visualizes where they occur during playback and derives a suggested record condition based on the measured defect density.
One of the difficult parts here is obviously distinguishing an actual record defect from legitimate musical transients such as snare drums, percussion or other short high-energy events.
The current detection pipeline therefore uses signal modelling and statistical thresholds rather than simply looking for amplitude peaks.
The resulting grading is intended as an additional measurement, not as a replacement for visual inspection or listening.
2. Before/after cleaning comparison
This was actually one of the main reasons I started building the project.
You can record the same record before and after cleaning and vinyl-check tries to match the two recordings.
It can then show which detected defects:
- disappeared after cleaning
- remained at approximately the same position
- appeared only in one recording
The idea is to make statements such as
“this record sounds cleaner after washing” somewhat more quantifiable.
It also creates some interesting data about which types of contamination can realistically be removed and which defects are probably permanent groove damage.
3. Turntable measurements
Using appropriate test records, vinyl-check can also analyze several aspects of the playback system, including:
- channel balance
- crosstalk / azimuth
- anti-skating
- cartridge / arm resonance
- rotational speed
- wow & flutter
The goal is not to invent new measurement methods here, but to make existing measurements easier to perform and interpret with normal consumer audio hardware.
Digital master comparison
Another experimental feature compares a vinyl recording against an available digital version of the same material.
This is useful because a transient detected in the vinyl recording may actually be part of the recording/master itself.
If the same transient exists at the corresponding position in the digital source, it should obviously not be counted as a vinyl defect.
Alignment between two versions of the same recording is one of the more interesting problems here because timing, level, EQ and even mastering may differ.
Local processing
All audio analysis happens locally.
The recordings do not have to be uploaded to a cloud service.
The software currently runs on:
- macOS
- Windows
- Linux
- Raspberry Pi
Private/non-commercial use is free.
The source code is available as well, although I describe the project as
source-available rather than Open Source, since the license restricts commercial use.
Project website:
https://vinylcheck.net/
What I am particularly interested in from the ASR community is criticism of the measurement methodology.
For example:
- How reproducible should defect counts be between two consecutive plays of the same record?
- What is an appropriate statistical definition of a click or pop?
- How should musical transients be separated from groove defects?
- How meaningful is a numeric condition score when stylus profile, cartridge, tracking force and playback chain influence the result?
- How much can different ADCs / phono stages affect comparability?
- Which turntable measurements are actually useful for setup, and which ones risk giving a false sense of precision?
- Would it make sense to establish reference recordings / test records for validating the algorithms?
I would also be very interested in recordings where the software clearly gets something wrong.
A clean result is nice, but a record where the detector completely falls apart is probably much more useful for improving it.
So please feel free to criticize the assumptions, thresholds and methodology.
That is mainly why I am posting it here.
Michael
