Can Vinyl Condition Be Measured Objectively? Introducing vinyl-check
michaelpietzsch
Hi everyone,
I’ve been working on a project called vinyl-check and I think this forum is probably one of the best places to get the methodology challenged properly.
The basic question behind it is:
How much of vinyl playback quality can actually be measured from the captured audio signal instead of being judged purely by listening?
vinyl-check records a side of a record through an audio interface and analyzes the resulting audio locally.
The project currently covers three main areas:
1. Record condition / defect detection​
The software detects transient defects such as:
  • clicks
  • pops
  • crackle
It then visualizes where they occur during playback and derives a suggested record condition based on the measured defect density.
One of the difficult parts here is obviously distinguishing an actual record defect from legitimate musical transients such as snare drums, percussion or other short high-energy events.
The current detection pipeline therefore uses signal modelling and statistical thresholds rather than simply looking for amplitude peaks.
The resulting grading is intended as an additional measurement, not as a replacement for visual inspection or listening.
2. Before/after cleaning comparison​
This was actually one of the main reasons I started building the project.
You can record the same record before and after cleaning and vinyl-check tries to match the two recordings.
It can then show which detected defects:
  • disappeared after cleaning
  • remained at approximately the same position
  • appeared only in one recording
The idea is to make statements such as “this record sounds cleaner after washing” somewhat more quantifiable.
It also creates some interesting data about which types of contamination can realistically be removed and which defects are probably permanent groove damage.
3. Turntable measurements​
Using appropriate test records, vinyl-check can also analyze several aspects of the playback system, including:
  • channel balance
  • crosstalk / azimuth
  • anti-skating
  • cartridge / arm resonance
  • rotational speed
  • wow & flutter
The goal is not to invent new measurement methods here, but to make existing measurements easier to perform and interpret with normal consumer audio hardware.
Digital master comparison​
Another experimental feature compares a vinyl recording against an available digital version of the same material.
This is useful because a transient detected in the vinyl recording may actually be part of the recording/master itself.
If the same transient exists at the corresponding position in the digital source, it should obviously not be counted as a vinyl defect.
Alignment between two versions of the same recording is one of the more interesting problems here because timing, level, EQ and even mastering may differ.
Local processing​
All audio analysis happens locally.
The recordings do not have to be uploaded to a cloud service.
The software currently runs on:
  • macOS
  • Windows
  • Linux
  • Raspberry Pi
Private/non-commercial use is free.
The source code is available as well, although I describe the project as source-available rather than Open Source, since the license restricts commercial use.
Project website:
https://vinylcheck.net/
What I am particularly interested in from the ASR community is criticism of the measurement methodology.
For example:
  • How reproducible should defect counts be between two consecutive plays of the same record?
  • What is an appropriate statistical definition of a click or pop?
  • How should musical transients be separated from groove defects?
  • How meaningful is a numeric condition score when stylus profile, cartridge, tracking force and playback chain influence the result?
  • How much can different ADCs / phono stages affect comparability?
  • Which turntable measurements are actually useful for setup, and which ones risk giving a false sense of precision?
  • Would it make sense to establish reference recordings / test records for validating the algorithms?
I would also be very interested in recordings where the software clearly gets something wrong.
A clean result is nice, but a record where the detector completely falls apart is probably much more useful for improving it.
So please feel free to criticize the assumptions, thresholds and methodology.
That is mainly why I am posting it here.
Michael
Hi Michael.
I've only just had a brief look at your website and I'll install the app later on Windows 11 and have a tinker. What I can say now is how thoroughly impressed I am with what you've achieved so far. The information on the website is so well presented and I have no doubt the app will be as equally impressive. I can see your app being a real boon for vinyl aficionados everywhere who demand the very best quality from their vinyl.
I invested a good chunk of change and time the past trying to maintain and improve the condition of my vinyl collection, including before and after cleaning comparisons using an ADC and Audacity. This tool would have been a blessing!
Superb work! :)
Basic assumption that the quality can be measured reliably. You largely need better quality like digital version to compare with. Like null test.
It’s only been an hour, but I’ve installed it, struggled through the user interface, and recorded a side.
Some notes:
I am only interested in records for which there is no readily available CD. Most of my records came from garage sales and are quite old. The most recent ones come from the 70s.
I made my own vacuum cleaner, which works pretty well. Unfortunately for the purpose of this test, I had already cleaned a record before testing. It got a near mint rating. Waxwing Magic on. The record was released in 1964 and has everything going against it. It was an even older mono recording, remastered for stereo. Vinalcheck gave the recording an F. (28dB music to noise)
Fascinating program, producing far more information than I can absorb.
It does seem to validate my cleaning process, even though I haven’t yet done a proper test.
He does say the following: "Another experimental feature compares a vinyl recording against an available digital version of the same material."
"Alignment between two versions of the same recording is one of the more interesting problems here because timing, level, EQ and even mastering may differ."
Such comparisons could of course be difficult to perform unless a CD or lossless rip is owned. However, it's good to know that the option to perform comparisons is available, even if it's experimental at the moment.
I cannot judge the objective accuracy of the program, but I can see record defects ( clicks, pops, crackle) in the SoundForge waveform, and this program seems to count them. If I were trying to do a professional restoration, I could locate defects using this program, and correct them in the editor.
I’m just beginning to realize what’s available in the program.
There’s a timeline that displayed the location of defects. If you try to locate them in SoundForge, you pretty much have to listen attentively to the whole recording and try to pause it when you hear a click. If you know the time of a click, it’s fairly easy to see it in the waveform. Otherwise, it’s difficult.
I have several tools for healing defects. With luck, you can heal them transparently.
So many nice stuff coming up, just need the time to test. Does it require recording live or can I drop recorded files on it?
Clearly, theere are many useful measurements that can be made....
The big issue is that the source medium (vinyl) is inconsistent, literally from copy to to copy, obviously in terms of dirt/dust/fly shit, but also in terms of the 'flatness' of each copy (the main reason a sub filter may be needed!). So you may find it hard to make proper/usable comparisons between various TT's, arms and cartridges.
I'm off to polish my FLAC files with some Mr Sheen... :)
We are here for challenge, not the easy stuff. :-)
Å
Is it possible to use already recorded wav files?
Lay the bits out and run a needle over them, maybe?
The analysis is digital. I see no compelling reason why the program can’t analyze a previously recorded disc.
On an unrelated note, I just caught autocomplete changing a word to a complete phrase that I didn’t intend.
The point I was making is that any analysis is unique to one copy of an LP...
It makes extrapolation of any generic conclusion a bit difficult.
But if the the thread is actually about testing just one LP, then fine!
I'll leave this thread alone - I admit that I cannot see any point in LPs and spinny machines. :)
Well, isn't that the purpose of the software? To grade copies of individual LPs?
