Birdcircles
- Joined
- Apr 1, 2026
- Messages
- 4
- Likes
- 3
Hi there ASR! Long-time lurker, first time poster here. I've been working towards a major system refresh and would like to run some principles I'm working from by you all to check their veracity and to get your thoughts. Currently I'm running a Cambridge Audio CXA81 amplifier, driving a pair of Dali Oberon 1 speakers, as well as a REL Tzero MKIII subwoofer. The source is a Bluesound Node (N130). I have added rudimentary tone control via the Schiit Loki Mini. (Yeah, it's a somewhat lopsided and rather WhatHifi-coded system. We all gotta start somewhere!)
The room is a 3 x 3 m square nook in my apartment living room. It's not a closed-off space; along one side it opens into the rest of the room.
On order is a pair of KEF LS50 Metas, my first speaker upgrade since purchasing the whole setup about five years ago. My end goal is to have a complete system with proper sub integration and room correction through some form of EQ/PEQ. I had initially intended to purchase a Dirac Live license for my Node and keep the sub connected high-level. This all stemmed from the belief that my amplifier was the costliest (and best) element of this setup, and I'd do well to keep it in the system.
However, after a long time spent reading this forum and other sources, like Erin's website and YouTube channel, I have come to understand/believe the following (please correct me if I'm wrong):
Thanks in advance!
- All amplifiers, when operating properly and matched with speakers that don't require more power than the amp can provide, will be audibly transparent under normal listening conditions
- As are all (properly functioning) DACs and streamers
- There is no audible difference between different forms of amplification (Class AB vs. Class D, in this case)
- Room correction, especially in a small space like mine, will have a far greater impact on the sound than any amp, DAC or streamer on its own
- A WiiM Amp Ultra could replace my entire Node + Loki + CXA81 setup and would, functionally and with regards to raw power, exceed it
- The WiiM Amp Ultra's amplification section will not be an audible downgrade from my CXA81, nor will its DAC
- The WiiM with its EQ / RC capabilities could eclipse the current setup in potential SQ, even without the new speakers; let alone when paired with the LS50s
- Proper bass management (meaning High- and Low pass filtering, plus time alignment) is superior to REL's preferred (and in my experience, annoyingly trial-and-error based) high level connection
- The WiiM Amp Ultra is plenty powerful enough to drive the LS50 Metas to my typical listening volume of 75 - 85dB
Thanks in advance!
