I coached retail audio selling for years, and this is about as perfect an example of a sales demo (tell them what they will hear, let them hear it, tell them what they heard) as I have seen.
I can't say I heard any difference on the PC speakers. But I skipped the sales talk.
So:
Played (part) of the video, recorded the first "compare" in PC and ran those into DeltaWave.
DeltaWave v1.0.26, 2019-04-25T10:28:54.6500618-04:00
Reference: jcat.wav[R] 280999 samples 44100Hz 16bits, stereo, MD5=00
Comparison: jcat-femto.wav[R] 280999 samples 44100Hz 16bits, stereo, MD5=00
Settings:
Gain:True, Remove DC:True
Non-linear Gain:False EQ FFT Size:65536, EQ Frequency Cut: 0Hz - 0Hz, EQ Threshold: -160dB
Correct Drift:True, Precision:30
Upsample:True, Window:Hann
Spectrum Window:Hann, Spectrum Size:524288
Spectrogram Window:Hann, Spectrogram Size:1024, Spectrogram Steps:256
Dither:False
Trim Silence:True
Discarding Reference: Start=0s, End=0s
Discarding Comparison: Start=0s, End=0s
Initial peak values Reference: -0.882dB Comparison: -0.782dB
Initial RMS values Reference: -17.43dB Comparison: -17.386dB
Null Depth=33.572dB
X-Correlation offset: -1 samples
Trimming 0 samples at start and 1 samples at the end that are below -90.31dB level
Drift computation quality, #1: Excellent (0.21μs)
Trimmed 25883 samples ( 586.9161ms) front, 0 samples ( 0.00ms end)
Final peak values Reference: -2.032dB Comparison: -2.368dB
Final RMS values Reference: -17.564dB Comparison: -17.515dB
Gain= 0.007dB (1.0008x) DC=0 Phase offset=-0.017858ms (-0.788 samples)
Difference (rms) = -39.95dB [-43.44dBA]
Correlated Null Depth=53.08dB [37.25dBA]
Clock drift: -0.22 ppm
Files are NOT a bit-perfect match (match=0.11%) at 16 bits
Files match @ 49.9965% when reduced to 6.6 bits
Phase difference (full bandwidth): 56.0339390853834°
0-10,000Hz: 37.3944318723206°
0-20,000Hz: 58.1178962794231°
0-24,000Hz: 56.0339390853834°
0-44,100Hz: 56.0339390853834°
0-48,000Hz: 56.0339390853834°
RMS of the difference of spectra: -127.443943197253dB
gn=0.999195979564436, dc=0, dr=-2.23337E-07, of=-0.7875223317
