Can Sound Blaster Audigy Fx Pro 7.1 be converted into external card ?
Ramon Cota
San Carlos
Hello . this card is advertised as having DAC of 120 db SNR , but in independent measeruments it fails to deliver these numbers ( https://www.igorslab.de/en/creative...and-measurements-compared-to-onboard-sound/3/ ) supposedly due to interference from graphics card , motherboard and what not. Being essentially a usb card , would it be possible to put it in a separate box and connect it to a pc with such pcie extension or maybe even straight to pcs usb port , and achieve much better results ?
The hardware hookup should work, but it all depends on how the noise is being carried. You can get induced pickup by local proximity between PC cards, but if the noise is carried on buses or power rails, it will still likely affect an external card. The only real way to know is to try the sound card on an extender.
I have an Asus Xonar Essence STX PCIe sound card - and I can achieve incredibly low noise levels with it.
I wonder why this wouldn't be possible with the Sound blaster? Perhaps it's not such a good card?
IIUC that card has PCI-e interface, so the shown PCIe-PCI adapter would do no help.
Theoretically you could disconnect the PCI-e - USB bridge from the Realtek codec and hook USB directly, but first it's quite complicated and second almost certainly there would be no audible advantage.
That measurement rig description is quite long, I did not get exactly the actual chain the reviewer used for measuring. I could not find any measured noise figures for the UAC-232 ADC part.
In my experience, adding these types of adapters lead to more issues than they solve.
If you don't need multi-channel audio or mic input, then I would replace the Sound Blaster PCI-e card with a Topping DX1 II or similar:
If you do need multi-channel and/or mic input, then one of the USB SoundBlaster devices might be appropriate - I augment my Topping DX5 II setup with a SoundBlaster X4 that I use for the odd gaming session with my son (I use it with Sennheiser HD560S with boom mic cable).
You can connect to an internal M.2 slot for the PCIe lane(s)
There are Thunderbolt adapters as well, may be better to avoid picking up RFI noise with ribbon cables
Look to the eGPU forums for quality box recommendations
Oculink ports are only needed for high bandwidth.
