Can someone comment on the build quality of this LPS - Thanks!!!!
The LPS did NOT flatten the dynamics of the music going via your router because it is physically impossible for it to do that in the universe we currently inhabit. Your brain is fooling you.
Yep. a 1's a 1 and a 0's a 0. Hard to get that confused. So unless the sent data changed, the sound couldn't change. It might be possible for digital audio sources to sound different if the signal, after it is converted from digital analog format, gets modified a bit by op amps and filters that handle the analog signal, but that is not all that likely, either, and any change is likely to be microscopic.(microsonic?).
