Can single-seat home theaters forgo the center speaker?
Kain
For single-seat Atmos home theaters, is it okay to forgo the center speaker? I asked ChatGPT and it said yes and even said it actually might be preferred? However, I forgot why it said it might actually be preferred since I don't have that chat anymore.
No. It's your best chance at hearing dialogue in TV/films, because background sounds are now so loud. Plus actors mumble these days and more effort is put into gimmick sound than clear dialogue these days (BBC sometimes excepted)
I am running a 4.0 system in my small living room, with Camilladsp handling the downmixing of the center channel. I apply a bit of eq before splitting the center channel into the mains, adjust volume and apply some compression. I live in an apartment and do not need super quiet dialog and loud explosions. Adding a center channel is just not practical in my setup.
It works very fine in my somewhat specific conditions. And I never had a proper center channel so cannot say what I am missing!
It is OK to not use a center speaker if you don't want to. If it works for you without one, thats great!
I prefer hearing all dialog from a single speaker as it sounds more natural. Dialog is locked into place. I have a fairly narrow room and even on my single seat I can shift the perceived direction of all dialog to the right or left of the screen by simply tilting my body into one of both directions (almost lying on my couch) if not using a center speaker.
On the other hand, many people are unable to put the center where it really belongs: Heightwise in line with LR speaker and in right configuration (horizontal vs. vertical placement). It is often placed under the TV and sometimes crammed into a low board. Like this:
Some people have trouble with this type of config because it "disconnects" the video from the audio. Ideally, all dialog should sound like it "pops" right out of the screen. In the above example you would need to disable the center.
You will probably need an AT-Screen to get the best of both worlds.
It's going to depend on whether your Atmos renderer has an option to render without a centre channel, or whether you have something else to mix the centre into left and right like @Zetti.
It is less than ideal but it may be 'okay'. Consider trying a configuration without a center channel and hearing if you have trouble understanding the dialogue.
No. Interaural crosstalk makes voices sound kind of hollow when a center was used in mastering. The phantom center is just an acoustical illusion with many drawbacks. When your room has really low decay time the voice is focussed more but you get more interaural crosstalk. Vice versa you have to live with a really wide image of voices. I also find that the more I treated my room the more focussed the voices got with a phantom center. But also the image moved towards me and shift slightly above the speakers. You can get used to it after some minutes but switching back to a center is always showing what was wrong.
In the end, it's only TV. If dialogue sounds OK, then no worries :)
I am music-first, films are only occasional and I haven't enabled "watching TV" in my home since the 70's.
Ideally as stated the physical Center speaker should be close to the same height as L/R
especially the voices section from lower-mid up to treble
Using an acoustically transparent screen with a good projector can enable that.
a sub can go under the screen.
If you use AVR type gear (I don't) apparently some units do have DSP settings to use L/R more effectively upmixing to create a strong "virtual Center" for dialogue.
I would not use that for critical listening to music, but prolly "good enough" for films and shows
I have run with and without a center and find phantom center imaging to be spotty at best. I would not do it again. The center is the "anchor" for dialogue and much of the content in TV and movies and, even with good speakers, if you move around a little the center image will shift without a center speaker. How much shift and how much it matter depends upon your system and you; it bothered the heck out of me, may not matter to you.
If the mix, be it Atmos or conventional 5.1/7.1, uses the center channel position, and you do not have a center channel speaker, you will not be hearing the mix as intended. Are you okay with that? If yes, then don't bother with a center channel speaker.
I'm quite certain that ChatGPT has never listened to music or watched a movie, and you can confidently ignore what it told you.
I prefer a physical center over a phantom center... so much so, I will actually use upmixers when I listen to stereo music and I think Atmos music sucks, because 99% of the mixes don't make use of the center channel.
Remember the finding that we become more critical listeners when we listen to a single speaker, and also, all sound sources in real life are effectively mono... if you don't like the sound of a center speaker, it's probably not a very good speaker and/or you haven't set it up well.
I agree with the group that says yes you can and that YMMV.
Personally, I wouldn't do this. The Center is truly the most important Speaker in HT. Sadly, it is usually the most bastardized, too, but that is a whole other story.
That said, you can opt to just do L and R, forego Center, and see how things progress. You might not mind, and if you do, you can always add it later.
Much like Subs... Do not skimp on the Center, if you add one. I use a vertical standmount 3-way as my Center. Crossed at 80, it does very well at its job.
And while my rig is designed for multi-channel music, it make a great crossover to HT and Gaming.
I beg to differ. This may be true of mass produced streaming Atmos pop, but not so of thoughtfully mixed Atmos music. Try, any blu ray (or streaming, I suppose) of Yello (Point and Touch), all Roxy Music and Bryan Ferry, all Mark Knopfler and Dire Straits, Booka Shade (all), Kraftwerk 3D Der Katalog, Beethoven Symphonies (DGG von Karajan 1970s reissue), and many many more. But perhaps not the particular artists that you are listening too . . .
Some seem to prefer a phantom center in that situation. Might depend somewhat on what center speaker you use. Personally I prefer a good capable center even though I'm the only one in the room most of the time, a 3-way preferably (if you can't use three identical speakers across the front).
I'm specifically talking about Atmos Music on Apple Music and Amazon Music, and encompasses many genres (including for example, classical). I'm sure the stuff you mention is very good, but easily fits into the 1%. Should I dial back my statement to 95% to be more accurate from your perspective? Older mixes such as 5.1, of which I know there is a large back catalog, definitely do not exhibit this phenomenon either.
I use old MartinLogans without center or subs. Dialog and soundstage are great. I think the height of the panels helps. I have no idea if I am missing something without additional subs.
It was only thanks to Apple's vast 3D audio catalog that I came across this piece of music, for example:
The artists mentioned by @BJL are also all on my list of favorites. I probably wouldn't have listened to Kraftwerk in the past, as I tend to prefer (easy-listening) 80s synth-pop or NewRetroWave. But "3-D The Catalogue" is absolutely amazing—even via streaming (wouldn't spend more than 200 euros on the Blu-ray).
On top of that, I’m now listening to R&B, jazz, and classical music etc. Genres I had absolutely no exposure to before. And of course, these tracks are often quite gimmicky and overloaded with effects, but just as often the mix is very flat and boring. It's all a matter of taste, but saying that 99% of it is rubbish? Bit too harsh imo.
Center speaker placed directly beneath the TV and angled slightly towards ear level — verything calibrated, and it definitely "pops".
Imo it can be.
My preference for music videos is phantom center mode (no center channel) as I think the sensation of soundstage depth is better without a center channel speaker.
For movies I don't really care, assuming the center channel speaker sounds good.
But as with most things audio, it depends on the specifics, hence "imo it can be" okay.
The real solution IMO is processing gear that lets me cycle between different modes as desired.
The physical center must be there for suitable content and use case, but it does not always get used
