But that's mostly because opamps don't have the super-low-Vnoise, super-low source impedance terrain covered particularly well (if al all) and those that do aren't cheap. Even then you generally wouldn't go all discrete though and merely use the super low rbb' transistors in a discrete input stage. This is one of those niche applications that do benefit from going discrete, particularly because at the same time other requirements like input voltage swing are modest so nobody cares about common-mode issues.Like anything it's down to application. Given the choice between a jfet opamp and a couple of pairs of zetex low noise, low rbb transistors for a mc input stage I'm taking the discrete option every time.
On the other end, opamp options quickly thin out once high voltages and/or currents are required. You can just about find some parts suitable for a higher-power headphone amplifier (although people have resorted to using speaker amplifier ICs, too), but at a certain point you're just better off going discrete, at least partially where it makes sense.
