I'm in kind of a pickle, I bought some headphones that went through this dual balanced mod on Etsy but it's been 2 days and the seller still has not responded to my inquiry so I have no clue whether or not I can use TS cables like this meze cable.
This is what he says on his listing:
As a complete newbie, if it's "wired as TS" that means on paper I should be able to use the meze TS cables I mentioned with no issues right? It will just be plugged into my JDS atom amp and I still haven't the slightest clue what balanced/TS/TRS/TSTSTSEST means.
With dual sided balanced mod, I will take out the stock cable, and the wire running to the right side driver, and then put a 3.5mm female jack on each side. By default, each jack will be wired as TS, as this is the most common dual 3.5mm cable configuration. If you are using a dual 3.5mm cable already from a different set of headphones, and are unsure if it will work with my dual sided mod, message me on Etsy to discuss. The holes left by the left-to-right cable will be sealed with hot glue. If you don't know what balanced is, you most likely don't need this mod.
