Can I get better sound quality (optical to gaming PC vs. dedicated streamer)
ZENERGiA
Hungary
Hi Guys,
I am using a Chord Mojo 2 connected to my gaming PC with an optical cable. I used to connect the Mojo 2 to my gaming PC with a USB cable, but to my surprise, changing to optical cable made the sound much more "fluent", if I guess correctly this might be because while using optical cable I get galvanic isolation?
I am quiet satisfied with the sound now, but I am looking for more improvements. Would using a dedicated streamer help with sound quality, and help me get the most out of my Chord Mojo 2, or the sound quality out of the Mojo 2 is as good as it gets using an optical cable and a gaming PC as my source? I have also tried using UAPP with my mobile phone and a good quality USB cable, but I was not satisfied with the sound quality.
My setup: Gaming PC -> Optical cable -> Chord Mojo 2 used in desktop mode with an iFi iPowerX -> AKG K371, AKG K712 PRO, Sennheiser HD560S, Sennheiser HD600, Audio-Technica AD700X (needs pad change), Grado SR225i (needs pad change).
Thank you in advance!
Wish you all a happy new year!
If there was any sound improvement at all going to optical, it can only be because you were getting noise (either from components in the PC or a ground loop) through the USB connection that were eliminated with the TOSLINK (or possibly there was some misconfiguration of bit/sample rates or unwanted processing affecting the USB interface). There isn't anything you could do to improve sound quality beyond what you have, which should be a bit perfect digital stream from the PC to your Chord.
This is good news, thank you very much! :)
Is there some way to test what was (is) wrong with my USB connection? I don't remember hearing noise when maxing out the volume on the Mojo 2 while not playing music, and I also use TIDAL in exclusive mode, So I am quiet puzzled what went wrong.
