My current setup looks like this... Macbook > ADI-2 DAC > Neumann KH750 sub > Neumann KH 80 monitors (L&R)
I used the MA-1 mic and Neumann software to take room measurements and apply room correction.
My question is... can I now use the PEQ on the ADI-2 to apply additional corrections? I don't see why not, but when i try, the adjustments don't seem to work as intended. For example, reducing the bass by -12.0 dB with the ADI-2 has only a minimal effect (shouldn't that amount be drastic?)
I purchased this setup hoping to use the built in DSP to get me to a "flat" response" and then have the ADI-2 setup with multiple "house curves"i could easily adjust or switch between without the need for the Neumann software (which i dont love).
Thanks,
Josh
Thanks,
Josh
