I'm wondering if I can possibly damage my headphone amp if I cut off its power, but still have signals coming in through the input and 12V trigger. I'm currently using a D50 III/A50 III stack hooked up to a P50 power supply. I have the DAC output through both the RCA(speakers) and TRS(A50 III) outputs at the same time. The stack is also hooked up through the 12V trigger. To save power, I have been shutting down the P50 to also turn off the headphone amp when I'm only listening to my speakers. Would this damage the A50 III since there is about 5Vrms running through the input, and whatever signal is running through the 12V trigger.
Would it also be bad to hook up the stack's outputs/inputs, and the 12V trigger while the units are on with with audio being played?
Looking through the manuals for both the DAC and amp, there are no warnings about doing any of this, so I'm not sure if it is possible to damage the amp or DAC in any of the situations described above.
I recently tried unplugging the 12V trigger, and I noticed the A50 III shutting off while audio is still being played. Most of the times this happens is when I put my headphones down and get up from my desktop. Not sure if I possibly damaged the A50 III during some time setting it up, turning it off while signals are running to it, or if it is faulty to begin with. I am not sure if the A50 III would've always behaved like this from the beginning, as I had the 12V trigger plugged in all the time preventing it from turning off while the DAC was on.
