What is feeding the Speaka? PC or Cell phone? Because, if a decent cellphone, and phone has 3.5mm jack, you should be able to directly connect it to the Atom with the same 3.5mm cable to RCA. The cellphone DAC may be as good as the Speaka, and if an LG G7, V20, V35 etc. - better.
But to answer your question, I believe Amir likes to see 2V out of a DAC, the Amps like the Atom are fine with this. For sure, you will likely need to 'crank up' the volume on whatever is feeding the Speaka to get anyway near 2V - so the short answer : you should be fine.
And I would not worry about distortion from the Atom, as by driving it with 2v or less, that is within what it is designed to accept. More likely is 'upstream distortion' (lower SINAD than the Atom ) from the Speaka..
