I don't think this was posted earlier, but a nice basic site for addressing "speaker wire" http://www.roger-russell.com/wire/wire.htm
Wouldn't just be better to get the strand count you need for flexibility rather than adding more wire to the mix? Covering with techflex or similar can be nicer looking and keep things physically together, sure, but really isn't necessary for good speaker wire performance otoh.Multiple wires, insulated from each other or not, make the cable easier to bend and handle. Twisting or covering wires with a sleeve keeps independent wires together and makes them easier to handle and route. No sonic advantages.
Of course, but the question I saw and answered was about two 10 AWG wires feeding a speaker, and how to group them together to make them easier to handle. Again, I came into this thread late, so have probably missed whatever the original ask was, and how many wires were involved. I only read about two, and that it was wire on hand, so no desire to buy additional wire (of any gauge and strand count).Wouldn't just be better to get the strand count you need for flexibility rather than adding more wire to the mix? Covering with techflex or similar can be nicer looking and keep things physically together, sure, but really isn't necessary for good speaker wire performance otoh.
I muddied the water asking about the two wires and yes you were correct one for the positive and one for the negative.Of course, but the question I saw and answered was about two 10 AWG wires feeding a speaker, and how to group them together to make them easier to handle. Again, I came into this thread late, so have probably missed whatever the original ask was, and how many wires were involved. I only read about two, and that it was wire on hand, so no desire to buy additional wire (of any gauge and strand count).
Sleeving is added for appearance and to make handling easier when dealing with multiple (two in this case) wires. I assumed the two wires were the (+) and (-) wires from amplifier to speaker. You can use wire ties, sleeving, or twists on any reasonable number of wires, natch.
I do not recall mentioning any electrical or sonic benefits.
If none of that is true, ignore my post, and I'll get the heck out of this thread.
Braiding wires, unlike ropes, is not something I have ever advocated. It is a lot of work, requires significantly more wire, increases capacitance, and any noise rejection advantages are insignificant in the vast majority of systems. If noise ingression is a problem, rare on speaker cables, there are other, better solutions like shielding and filter circuits that I would do before (and instead of) braiding the wires. Audio is not GHz signals that may (or may not) benefit from braiding, and even for RF cables braiding is very rare as there are other cheaper, simpler solutions.I muddied the water asking about the two wires and yes you were correct one for the positive and one for the negative.
I also misread your post and that’s why I said braiding probably because someone had mentioned that type of diy wire on a previous post.
In any case I appreciate the engagement. It’s given me food for thought about how I want to manage my speaker wires.
Just a hint: you can cut everything in this link starting with the first question mark:
