Now that’s a good one. There is so many possibilities to get him that he has no idea what anything in home audio is about and specially hifi cables. lolTell your boss the longer your premium cables the more you maximize the number of micro acoustic subparticals which directly increases the amount of harmonic fusion preasure resulting in explosive dynamics when released all at once as sound.
Then build him some 100 yard cables and explain he needs to run them up the stairs, down the stairs, around the attic, through the kids room, and out their window, around the outdoor hot tub then through the kitchen before connecting the speakers to maintain proper subatomic woofer and tweeter particle separation.
Before and after pics please.![]()
You can thread the two wires through the sleeve. But it might be easier and cheaper to simply twist the two wires together loosely, or use cable ties or some other means of keeping them together. The braid may look better if you prefer.I have a practical question based on the discussion. I bought a large roll of monster power wire for car stereo install years ago. Cheap. It was from a bulk reseller and it was a partial roll. All is gone now but I still use a set for my main speakers. The cable is supple and 10AWG if I recall. It’s overkill, but I own them already. What I don’t love is that the positive and negative are each independent wires not connected in a pair. I saw the braided sleeves mentioned earlier and wondered how that is applied because it would simply using these slightly vs running two independent strands of wire to the speaker.
Look up "wire loom" on Amazon. Generally, you feed the two wires through and then use a heat gun to shrink the loom. Some are hard plastic and don't require the heat gun. If you do this, be sure to mark the ends of your cables in some way in order to keep them in phase.I saw the braided sleeves mentioned earlier and wondered how that is applied because it would simply using these slightly vs running two independent strands of wire to the speaker.
Thanks! I have color coded banana plugs on them and the insulation sleeve while identical was marked by me with a sharpie with +++ or - - -Look up "wire loom" on Amazon. Generally, you feed the two wires through and then use a heat gun to shrink the loom. Some are hard plastic and don't require the heat gun. If you do this, be sure to mark the ends of your cables in some way in order to keep them in phase.
Braiding would use a lot of length. These are also already thick (not excessively so, but thicker than most). Cable ties… I agree it would do the job, I don’t love the way they can be sharp after you cut the excess off. Maybe Velcro ties? I will think about this option. Thanks.You can thread the two wires through the sleeve. But it might be easier and cheaper to simply twist the two wires together loosely, or use cable ties or some other means of keeping them together. The braid may look better if you prefer.
Are you talking about a braided sleeve or actually braiding the wires? I would twist, not braid them, and loosely so not much loss of length. You can get sleeves that are solid or braided in rolls you cut to length. I am not sure I understand what you are saying (writing).Braiding would use a lot of length.
10 AWG is not all that thick. Mine are twisted but with very low turn ratio; more for looks and ease of handling than noise rejection.These are also already thick (not excessively so, but thicker than most).
Yes, I had Velcro ties in mind, not zip ties, sorry I was not clear. You can buy them fairly cheaply. Here is one -- I have no experience with this particular brand, just came up in a quick search.Cable ties… I agree it would do the job, I don’t love the way they can be sharp after you cut the excess off. Maybe Velcro ties? I will think about this option. Thanks.
Appreciate Your engagement into this basic 'how to', maybe further generations may profit too (by finding this via 'saerch').Are you talking about a braided sleeve or actually braiding the wires? I would twist, not braid them, and loosely so not much loss of length. You can get sleeves that are solid or braided in rolls you cut to length. I am not sure I understand what you are saying (writing).
Amazon.com: 60 PCS 6 Inches Reusable Cable Ties - Cable Management Adjustable Cord Straps Wire Organizer Cord Wrap and Hook Loop Cable Management with Hook and Loop for Home, Office, Data Center Wire Organizer : Electronics
Buy 60 PCS 6 Inches Reusable Cable Ties - Cable Management Adjustable Cord Straps Wire Organizer Cord Wrap and Hook Loop Cable Management with Hook and Loop for Home, Office, Data Center Wire Organizer: Cable Ties - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
Zip ties are also prone to cutting the insulation when pulled tight, are a PITA to remove, and do not allow the wires to shift when bending and such thus reducing ease of handling the cables, so I use them for fixed runs as on a car frame, and not for speaker or interconnect/microphone cables.
Awesome job explaining the process and great job with your helpful post. Where were you at the beginning of this thread? This is what I was asking about. Thanks again for sharing and clarifying this information.Are you talking about a braided sleeve or actually braiding the wires? I would twist, not braid them, and loosely so not much loss of length. You can get sleeves that are solid or braided in rolls you cut to length. I am not sure I understand what you are saying (writing).
Then again there's no particular advantage to using multiple wires or twisting/braiding them for speaker wire....Awesome job explaining the process and great job with your helpful post. Where were you at the beginning of this thread? This is what I was asking about. Thanks again for sharing and clarifying this information.
Thank you both!Awesome job explaining the process and great job with your helpful post. Where were you at the beginning of this thread? This is what I was asking about. Thanks again for sharing and clarifying this information.
Multiple wires, insulated from each other or not, make the cable easier to bend and handle. Twisting or covering wires with a sleeve keeps independent wires together and makes them easier to handle and route. No sonic advantages.Then again there's no particular advantage to using multiple wires or twisting/braiding them for speaker wire....
