Can Horns Take Place of Waveguides
audioresearch
Some speaker systems are using waveguides on the tweeter to narrow its soundfield to more closely match that of the midrange in their crossover region.
Could not the same thing be done using a horn tweeter and horn midrange of the correct horn designs?
A waveguide is a type of horn.
What you're proposing has been done since 1925 with large cinema horns and later for the home market with different sized horns.
Below is my horn system as an example. Constant and narrow directivity in both planes and matching directivity between the two horns. However, the "tweeter horn" also covers here most of the midrange.
Klipsch and Avantgarde are examples of commercial home speakers with tweeter and midrange horns. The directivity isn't super constant though and Avantgarde often sounds colored/resonant.
There are various pro speaker with horns also.
Are these horns or a waveguides?
Avantgarde Acoustic Zero 1 Pro
That looks gorgeous!
What are they?
Waveguides and horns are practically synonymous.
Horns are for loading, while waveguides are for shaping radiation. They combine in deep waveguides/short horns, where some of both characteristics are found.
For crossovers and on-axis sound, yes, but not for spatial radiation beyond seat-to-seat measurements of steady state response. The HF/MF solution for cinema spaces was a multicell horn, for example.
In that era (I'm sure you know all this; it's meant for other readers), discs, plates and cylinders were all used for loading. Horns were eventually proven as the most efficient but were rudimentary at first, many having straight or conical sides. Complex curved shapes followed, like exponential and tractrix horns.
Horn limitations in a PA context were known, as was speaker radiation generally, but there was no attempt to use the principles of waveguides deliberately the way we see today to shape anechoic off-axis response until probably the 70s, with Don Keele's work at JBL on horn shapes. Modern shallow waveguides weren't really seen until the 80s as far as I know.
What are they?
A 2-way horn speaker with 80x50° directivity with broadband constant directivity, low crossover, active with DSP, and with the use of separate subwoofers.
Was meant to be sold under the brand name of Vera Audio, but has been paused because the compression driver with beryllium isn't available at the moment.
I don't think that's accurate.
A horn is not merely a device for loading a driver; it also shapes the radiation pattern. Likewise, a waveguide is not exclusively a directivity-control device, as it can also affect the acoustic load presented to the driver.
The more useful distinction is perhaps quantitative: how much acoustic loading does the geometry provide.
Multicell horns were already designed to control directivity long before Keele's work. While they may not have achieved the same degree of control as later designs, deliberate control of radiation was certainly not new in the 1970s. The relevant question is how well their directivity matched that of the midbass horns they were used with. I haven seen measurements here to conclude anything. Have you?
However, with crossover frequencies as low as 400–500 Hz in Altec systems, including those using multicell horns, directivity matching across a wider listening area was likely reasonably good.
We are saying the same thing about ultimate function. The only reason it is useful make the conceptual distinction is that horns were developed first and their main purpose, along with the supporting math (e.g., Webster's horn equation), was specifically about loading and efficiency. The requirement to shape offaxis sound on an anechoic, not a steady-state, basis came with the development of waveguides.
The distinction is that, while multicell horns control directivity, but their impacts were not assessed in terms their anechoic radiation pattern at the time of their design. We look at these things with modern eyes now.
The best work on horns is Kolbrek, Bjorn and Dunker, Thomas. High Quality Horn Loudspeaker Systems: History, Theory and Design. Kolbrek Elektroakustikk. 2019.
They authors measured the Western Electric 15-A horn here: https://www.audiosciencereview.com/forum/index.php?threads/ancient-loudspeakers.64117/#post-2351480
Joseph Crowe measured a midcentury multicell horn here: https://www.audiosciencereview.com/forum/index.php?threads/ancient-loudspeakers.64117/#post-2351489
As a side note. I was quite a bit shocked when I saw Klipsch released a horn with multicell horn. While multicell horn offers some constant directivity, the comb filtering issues are very obvious at closer distances at home - and it doesn't take much effort today to design something much better.
Looking at how Klipsch and JBL design speakers today, it's seems to be the following statement to me: "Since we're already big and famous, we can do whatever we want - customers will likely not know any better either way".
As mentioned above (several times) a horn is a type of waveguide. IME most people saying "horn speaker" think of a (horn) waveguide attached to a compression driver; I tend to think "waveguide" is more a marketing term to distinguish a speaker system comprised of a conventional driver coupled to a waveguide versus a compression driver coupled to a waveguide (horn).
I have a very vague memory from my old acoustics class of discussing them, and IIRC (not a given!), the system of what was called "horn equations" was a reduced set of waveguide equations, with the latter coming from field theory starting from the wave equation. Which made my brain hurt so I am not going to look it up again.
I bought the book "High Quality Horn Loudspeaker Systems: History, Theory and Design. Kolbrek Elektroakustikk" years ago, but sent it straight to Don Keele as a gift. I have never read it myself unfortunately.
Below is a converted sonogram of the WE 15-A, assuming 3 dB contour step.
AI generated from the scans I posted?
