if this receiver only drive one channel speaker , can it reproduce full bandwidth 20hz-20khz without any loss
Number of Power Amps
7
Maximum Continuous Output (1% THD) (20Hz - 20kHz, Two Channels Driven @ 8Ω) Channels: 1~5
140 W
Maximum Continuous Output (1% THD) (20Hz - 20kHz, Two Channels Driven @ 6Ω) Channels: 1~5
170 W
Maximum Continuous Output (1% THD) (20Hz - 20kHz, Two Channels Driven @ 8Ω) Channels: Remaining
60 W
Maximum Continuous Output (1% THD) (20Hz - 20kHz, Two Channels Driven @ 6Ω) Channels: Remaining
75 W
Speaker Impedance
>4Ω
channels
2
Power Output RMS (Per Channel) 8Ω
225 W
Power Output RMS (Per Channel) 4Ω
400 W
Power Output RMS (Per Channel) 2Ω
600 W
Power Bandwidth
90 kHz (-3 dB at 200 W into 8 ohms)
Input Sensitivity
1.5 Vrms (225 W into 8 Ω)
Input Impedance
10kΩ (RCA), 15kΩ (XLR)
Voltage Gain
29 dB
Slew Rate
30 V/μs
Frequency Response
8Ω = 20 Hz - 20 kHz ± 0.1 dB 4Ω = 20 Hz - 20 kHz ± 0.1 dB 2Ω = 20 Hz - 20 kHz ± 0.2 dB
Channel Separation
n/a
Crosstalk
n/a
Signal-to-Noise Ratio
120 dB (IEC-A, ref. 225 W)
Total Harmonic Distortion + Noise
0.0010% (1 kHz), 0.002% (20 kHz) @ 100 W
Intermodulation Distortion
ITU-R (19 kHz + 20 kHz) 0.0005% @ 100 W SMPTE (60 Hz + 7 kHz) 0.002% @ 100 W
Damping Factor
(20 Hz - 1 kHz) 300
7
140 W
170 W
60 W
75 W
Speaker Impedance
>4Ω
channels
2
225 W
400 W
600 W
Power Bandwidth
Input Sensitivity
Input Impedance
Voltage Gain
29 dB
Slew Rate
30 V/μs
Frequency Response
Channel Separation
n/a
Crosstalk
n/a
Damping Factor
(20 Hz - 1 kHz) 300
