can av integ. receiver driver big size bookshelf speaker?
derekchan
it is a mrx740,can it driver 7 unit of 4312g or 7 unit of mk s150 latest edition
do i need expensive ati multi channel power amp to driver these large size speaker with a av processor?
does it worth to upgrade from av receiver with poor power handling to av processor with giant tank ATI power amp
  • Number of Power Amps​
    7
  • Maximum Continuous Output (1% THD) (20Hz - 20kHz, Two Channels Driven @ 8Ω) Channels: 1~5​
    140 W
  • Maximum Continuous Output (1% THD) (20Hz - 20kHz, Two Channels Driven @ 6Ω) Channels: 1~5​
    170 W
  • Maximum Continuous Output (1% THD) (20Hz - 20kHz, Two Channels Driven @ 8Ω) Channels: Remaining​
    60 W
  • Maximum Continuous Output (1% THD) (20Hz - 20kHz, Two Channels Driven @ 6Ω) Channels: Remaining​
    75 W
  • Speaker Impedance​
    >4Ω
The short answer is NO. The longer answer requires you to jettison a misconception...
"big size bookshelf..." "large size speaker..." You need to stop looking at the physical size of the speaker - it's not directly relevant to how hard the speaker is to drive &/or whether a power amp is required. Larger speakers are generally more sensitive and therefore dissipate less power to reach a given SPL compared to smaller speakers.
Amplifier requirements depend mainly on speaker sensitivity, listening distance and desired maximum listening SPL's. Here's a couple of decent calculators:
Why/how have you identified seven of either of those particular speakers? (I assume a that's a JBL 4312G?) For a ~$18K multichannel speaker system, they wouldn't be my first choice.
