This is HF144.Strange FR.
XT1464 with another drivers, from VoceCoil:
50 cm should be fine, they all look similar. slighly off-axis would be like 5 or 10 deg. Just to see if the phase plug has some effect. You should normally keep pointing the mic towards the driver's center.At the same distances, 1m, 50cm & 5cm?
What do we call slightly off axis?
Does the Mic still point towards the driver or just point forwards i.e. do I just move the mic up/down, left/right or do I move the mic and angle its line of sight towards the driver?
Then it's better to ask upfront, rightSorry for all the questions, I don't want to waste everyone's time by doing the test wrong.........
Well, I ruled that out because the HF144 didn't show a similar dropoff. To be sure: what filter do you use?Could it be down to the DAC filter in the Eversolo pre-amp?
Your mic calibration file shows a rising treble response, which means that it is likely to be non-inverted. Cal files may be supplied in inverted or non-inverted format, and measurement software sometimes inverts it for you (REW) or requires you to perform a manual inversion. In other words, your cal file is fine.
Can you please tell us (1) what mic you are using, (2) whether you are pointing it on-axis to the tweeter or straight up, (3) whether you have cal files for horizontal and vertical orientation?
